Electrons impinging on a crystal
The discussion revolves around calculating the energy of electrons impinging on a crystal with a spacing of 0.4 nm using Bragg's law and De Broglie wavelength. The initial calculation yields an energy of 2.35 eV, which does not match expected options. Participants suggest that using a wavelength of 0.4 nm instead of the derived value would provide a more accurate estimate. This adjustment results in a momentum that is doubled and an energy that is approximately four times greater, leading to an estimated energy of around 10 eV. The conversation emphasizes the importance of using appropriate values for wavelength in relation to lattice spacing for accurate results.
tanaygupta2000
Under certain conditions, a beam of electrons impinging on a crystal surface will diffract and a
scattering pattern of the beam can be obtained. What is the approximate kinetic energy of the electrons needed in order to the see the pattern?
(Assume the lattice spacing of the crystal to be 0.4 nm)
(a) 100 eV (b) 1 eV (c) 0.1 eV (d) 10 eV
Bragg's law. 2d sinθ = nλ
De-broglie wavelength, λ = h/p
Since the crystal spacing is given to be 0.4 nm, so d = 0.4 nm = 4e-10 m in Bragg's law formula
For θ = 90° & n = 1, I got λ = 2d = 8e-10 m
Using this value in De-broglie wavelength, I got p = h/λ = 8.28e-25
Now kinetic energy of the electrons is given by E = p^2/2m
Using value of p, I am getting E = 2.35 eV, which doesn't seem to match any option.
Where am I doing mistake?
Please help!
90o is extreme. An interference pattern can be observed for n = 1 with small ##\theta##.
The problem is asking for an approximate answer. The general idea is that you need ##\lambda## to be "on the order of" the lattice spacing. So, what energy do you get if you take ##\lambda = 0.4## nm?
Likes berkeman and Delta2
p would get doubled and E would get 4 times, i.e., 4×2.35 eV = 9.4 eV ≈ 10 eV
Likes TSny and Delta2
Thank You so much for the help !
Likes TSny
