Electrons in Electric Fields: Examining Changes
When an electron moves through an electric field, its position and velocity change due to the force exerted by the field, described by the equation F_E=Eq_e. Classical physics posits that the electron itself remains unchanged as it is treated as a point particle with all its charge concentrated at a single point. The electron can either gain or lose kinetic energy, resulting in acceleration or deceleration depending on the electric field's direction and intensity. Additionally, the electron's trajectory can be altered, allowing it to deflect or curve. Overall, while the electron's intrinsic properties remain constant, its motion is significantly affected by the electric field.
Magnetons
What changes occur in electron, whenit through in a electric field
According to classical physics nothing changes in the charge distribution of electron as electron is considered to be a point particle and all its charge is concentrated in one point of space.
The only change that can happen is in the position and velocity of electron as electron will experience the force from the electric field ##F_E=Eq_e## (where E the intensity of the electric field) and if this force is the only force upon the electron then according to classical mechanics (and neglecting the energy lost due to EM radiation from the electron being accelerating) we ll have $$Eq_e=m_e\frac{d^2x}{dt^2}$$ where ##q_e,m_e## the charge and mass of electron respectively and ##x(t)## its position as function of time.
@Magnetons to put it shortly and in plain english, nothing changes "in the electron" itself and truth be told there is no such thing as "inside an electron", at least to the best of our current knowledge. But electrons do have properties, an E field can basically either accelerate or decelerate an electron. So the electron either gains or loses kinetic energy.
depending on the trajectory , kinetic energy of the electron and the E field line direction applied the electron can be either accelerated or decelerated in straight lines or deflected and bent from a straight trajectory into a curve, or it's trajectory can be changed by certain angle.
Some old small CRT's used E field instead of B field to deflect the electron beam
Magnetons said:
Summary:: Question
It could either slow down or speed up and/or change its direction of motion. In other words, it accelerates.
Likes Magnetons and vanhees71
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
