Electrons in s-robital shielding outer electrons
In summary, electrons in the spherical s-orbital are able to shield the outer electrons from the nucleus more effectively because they are centrally located, whereas electrons in the p and subsequent orbitals are more spread out and do not provide as strong of a shield. This can be explained by looking at the different shapes of the S and P orbitals and how the electrons are distributed within them.
kay
60
Why do electrons present in spherical shaped s-orbital shield the outer electrons from the nucleus more effectively as compared to electrons present in p and subsequent orbitals?
Please explain in a layman language I'm just in class 11th. :/
Consider what the S and P orbital look like:
Electrons in the S orbital hang out around the center of the atom, hence providing a pretty good shield. You can see the electrons in the P orbitals are kinda hanging out on the side of the atom often straight out in the x, y or z direction.
But why and how would being around the nucleus affect shielding effect?
FAQ: Electrons in s-robital shielding outer electrons
What is an s-orbital in terms of electron configuration?
An s-orbital is a spherical region in an atom where there is a high probability of finding an electron. It can hold a maximum of 2 electrons and is the first orbital to be filled in an electron configuration.
How do electrons in s-orbitals shield outer electrons?
Electrons in s-orbitals can shield outer electrons by repelling them with their negative charge. This results in a decrease in the effective nuclear charge experienced by the outer electrons, making them easier to remove.
What are outer electrons and why are they important in electron shielding?
Outer electrons are the electrons in the highest energy level of an atom. They are important in electron shielding because they are the most easily affected by the repulsion from electrons in s-orbitals, causing a decrease in their effective nuclear charge.
How does electron shielding affect the reactivity of an atom?
Electron shielding can affect the reactivity of an atom by making it easier for outer electrons to be removed. This can result in an increase in reactivity, as atoms with fewer outer electrons are more likely to form bonds with other atoms.
Can electron shielding be overcome?
Yes, electron shielding can be overcome by increasing the effective nuclear charge experienced by the outer electrons. This can be achieved by adding more protons to the nucleus or by removing electrons from inner energy levels, resulting in a stronger attraction between the nucleus and outer electrons.
