Electrons moving in an electric field
In summary: Correct - it should be sin(2A)=2sinAcosA.In summary, the angle at which the electrons leave the plate is θ=tan-1(2H/R).
ooohffff
74
Suppose electrons enter the electric field midway between two plates at an angle θ0 to the horizontal, as shown in the figure, where L = 5.1 cm and H = 1.1 cm. The path is symmetrical, so they leave at the same angle θ0 and just barely miss the top plate. What is θ0? Ignore fringing of the field.
F = qE
Not sure where to start but I'm assuming I have to break things into components and that there's trig involved...
Very good - that is an excellent start.
You have actually done problems like this before.
Hint: the electron is a projectile fired at an angle to the horizontal in a uniform vertical force field
Indeed you can solve it by using projectile motion. By getting the ratio of maximum heights (H) and the range (L), you can determine the angle.
Got the answer! Thanks!
Can you demonstrate that mathematically? Somehow I doubt that it is so o_O
Likes SammyS
For the benefit of someone else with the same issue, please post what you did.
The motion of electrons can be calculated by using the equations of projectile motion.
The electrons reach the maximum height at
H= v2*(sin(θ))2/2*g
and leave the plate at the range of
R=v2sin(2θ)/g
(Note: H is the distance between two plates, R is the length of plate, v is the initial velocity of electron, g is the acceleration acts on the electron )
by getting the ratio, we can eliminate the v and g by division thus leads to
H/R= sin2(θ)/2sin(2θ)
from the identity of trigonometry we know that 2sin(2θ)=2sinθcosθ
Therefore,
tanθ=2H/R. Put in the values of H and R we get
θ=tan-1(2H/R)
Likes Simon Bridge and gneill
H= v2*(sin(θ))2/2*g
R=v2sin(2θ)/g
Therefore,
θ=tan-1(2H/R)
Nice. I didn't see that as what you were implying from your hint.
Likes Simon Bridge
H= v2*(sin(θ))2/2*g
R=v2sin(2θ)/g
Therefore,
θ=tan-1(2H/R)
2sin(2θ)=2sinθcosθ?
Shouldn't it be sin(2A)=2sinAcosA?
Related to Electrons moving in an electric field
1. What is an electric field?
An electric field is a region in space where an electrically charged particle experiences a force.
2. How do electrons move in an electric field?
Electrons in an electric field will experience a force and will move in the direction of the field if they are negatively charged, or in the opposite direction if they are positively charged.
3. What factors affect the movement of electrons in an electric field?
The strength of the electric field, the charge of the electron, and the presence of other charged particles in the field can all affect the movement of electrons in an electric field.
4. How does the movement of electrons in an electric field generate electricity?
When electrons move in an electric field, they create an electric current. This current can be harnessed to power devices and perform work.
5. Can the speed of electrons in an electric field be controlled?
Yes, the speed of electrons in an electric field can be controlled by adjusting the strength of the field or by using materials with different conductivity. This is how electronic devices, such as transistors, are able to function.
