LHarriger
- 69
I just came across Earnshaw's Theorem which states:
A charged particle cannot be held in stable equilibrium by electrostatic forces alone.
As an example it said that equal and fixed point charges at the corners of a cube could not hold stationary a point charge at the center.
There was no proof provided, but after a little thought it occurred to me that Poisson's Equation for the potential would reduce to Laplace's Equation:
[itex] \nabla^{2}V=-\frac{\rho}{\epsilon_{0}} \Longrightarrow \nabla^{2}V=0[/itex]
since there is no charge anywhere but at the corners.
Because Laplace's Equation does not allow solutions with local maxima or minima then it would be impossible to find a a stable configuration.
Mathematically this seems fine. However, visually it seems that if I were to lightly tap the charge at the center then it would feel a repulsion pushing it back to the center (causing it to then oscillate about the center). Clearly this is wrong. Does anyone know of a physical way to imagine the instability?
