Electrostatic energy of concentric shells
In summary, the energy stored in a capacitor charged to q is
Data Base Erased
What's the electrostatic energy associated with two concentric shells with radii ##a## and ##b##, ##b > a##? The outer shell has a charge of ##-q##, the inner shell's charge is ##q##
##W = \frac{\epsilon_{0}}{2}\int |\vec{E}|² d \tau##
##W = \frac{1}{2} \int \rho V d \tau##
I know the energy is ##\frac{q²}{ 8 \pi \epsilon_{0}}( \frac{1}{a} - \frac{1}{b})##, but I can't get this result using the second equation.
What I did:
##W = \frac{1}{2} \int \rho V d \tau ##
##\rho = \frac{q}{ \frac{4}{3} \pi r³}, a < r < b ##
##V = \frac{q}{4 \pi \epsilon_{0} r}##
## W = \frac{ 3 q²} {16 \pi² \epsilon_{0}} \int 4 \pi \frac {r²}{r⁴} dr = \frac{3 q²}{ 8 \pi \epsilon_{0}}( \frac{1}{a} - \frac{1}{b})##
I didn't get rid of that factor of 3, where did I go wrong?
This is a spherical capacitor set up. What is the energy stored in a capacitor charged to q?
Using equations with ##\rho## makes no sense here.
##\rho## is the charge density for charge spread throughout a 3D volume (a simlple example is solid insulating sphere with the charge uniformly distributed throughout the sphere).
##\rho## is irrelevant here because we have have charges distributed on (infinitely thin) spherical shells, with nothing in-between the shells.
Your first equation ##W = \frac{\epsilon_{0}}{2}\int |\vec{E}|² d \tau
## might be more useful because it gives the energy stored in the electric field (in the space between the shells), which is is what is required.
Steve4Physics said:
Using equations with ρ makes no sense here.
ρ is the charge density for charge spread throughout a 3D volume (a simlple example is solid insulating sphere with the charge uniformly distributed throughout the sphere).
ρ is irrelevant here because we have have charges distributed on (infinitely thin) spherical shells, with nothing in-between the shells.
`I agree it's a bad approach to try working with ##\rho##, but we can define a perfectly workable definition of ##\rho## for an infinitely thin shell (or in this case, two shells) by way of the Dirac delta,$$\rho(r) = \frac{q}{4\pi a^2} \delta(r - a) - \frac{q}{4\pi b^2} \delta(r - b)$$
Likes Steve4Physics
Using the formula for capacitance of a spherical capacitor seems a bit of a cheat. Then again, doing the double area integral over the shells is overkill.
A third way is to calculate the potential at each shell and think about work done as charge leaks away to infinity from each at the same rate.
etotheipi said:
`I agree it's a bad approach to try working with ##\rho##, but we can define a perfectly workable definition of ##\rho## for an infinitely thin shell by way of the Dirac delta,$$\rho(r) = \frac{q}{4\pi a^2} \delta(r - a) - \frac{q}{4\pi b^2} \delta(r - b)$$
True. I said what I said because the OP was mis-using ##\rho## and clearly not understanding its interpretation and (conventional )use. I just wanted to emphasise that (at the expense of some rigour as you point out!).
Likes etotheipi
Yeah, I suspected this was the case and agree with what you were telling the OP. I just think delta functions are cool, and couldn't resist writing it out 😜
Likes Steve4Physics
Lol
For a conductor, the potential ##V## is constant. So, when doing the integral ##\frac{1}{2} \int \rho V d \tau## for one of the conducting shells, you can pull ##V## out of the integral. I don't think it matters that the charge is distributed on the surface of the conductor rather than throughout some volume of the conductor. You can always imagine in this case that the surface charge has an infinitesimal thickness so that it can be treated as a volume charge distribution. Or, you can replace ##\frac{1}{2} \int \rho V d \tau## by a surface integral ##\frac{1}{2} \int \sigma V d A##.
Yes, etotheipi has already explained how to do this in post #4. (And see my reply in post #6.)
OK.
Once you pull the potential ##V## out of the integral, then the remaining integral is just the charge on the conductor (without worrying how the charge is distributed on the conductor). I think maybe the OP was not seeing that. So, using ##\frac12 \int \rho V d\tau## is a nice way to get to the answer. It quickly yields the general capacitor formula ##U = \frac 12 Q \Delta V##.
Likes Steve4Physics and etotheipi
Yeah, viz$$\begin{align*}U &= \frac{1}{2}\phi_a \int_{\mathbb{R}^3} \frac{q}{4\pi a^2} \delta(r-a) dV - \frac{1}{2} \phi_b \int_{\mathbb{R}^3} \frac{q}{4\pi b^2} \delta(r-b) dV \\
&= \frac{1}{2}q(\phi_a - \phi_b)\end{align*}$$
Likes TSny
Related to Electrostatic energy of concentric shells
1. What is electrostatic energy of concentric shells?
Electrostatic energy of concentric shells refers to the potential energy that exists between two concentric conductive shells due to the presence of static electric charges on them.
2. How is the electrostatic energy of concentric shells calculated?
The electrostatic energy of concentric shells can be calculated using the formula U = (Q1 * Q2) / (4πεr), where U is the electrostatic energy, Q1 and Q2 are the charges on the two shells, ε is the permittivity of the medium between the shells, and r is the distance between the shells.
3. What factors affect the electrostatic energy of concentric shells?
The electrostatic energy of concentric shells is affected by the magnitude of the charges on the shells, the distance between the shells, and the permittivity of the medium between the shells. It is also influenced by the presence of any other charges or conductors in the vicinity.
4. How does the electrostatic energy of concentric shells relate to the electric field?
The electrostatic energy of concentric shells is directly proportional to the electric field between the shells. As the electric field increases, the electrostatic energy also increases, and vice versa.
5. What are some real-world applications of electrostatic energy of concentric shells?
The electrostatic energy of concentric shells has practical applications in various fields, such as in the design of capacitors, in the study of lightning and thunderstorms, and in the construction of Van de Graaff generators. It also plays a role in the stability of atoms and molecules in chemistry and physics.
