Electrostatic energy of three charges
In summary, the question involves two equal charges of magnitude Q placed at a distance d apart, with a third charge -Q/2 brought midway between them. The electrostatic energy of the system is found to be -E, with the significance of the negative energy being that energy is released when the charges are brought to their positions. The term "potential" may refer to either potential energy or potential difference (voltage).
Vibhor
971
40
Two equal charges of magnitude Q each are placed at a distance d apart .Their electrostatic energy is E. A third charge -Q/2 is brought midway between these two charges .The electrostatic energy of the system is now
A) -2E
B) -E
C) 0
D) E
EPE = kq1q2/r
[/B]
The question is quite simple and I have correctly found the answer which is -E i.e option B).
Now what is puzzling me is the signifance of negative electrostatic potential energy of this configuration . By definition of EPE , since energy of this configuration is negative then this means that when a unit test charge is brought from infinity towards the configuration, it experiences an attractive force .But from a far off point , the configuration should look like a net positive charge .Thus , configuration of these charges should repel test charge .
What is the significance of minus sign in the EPE of this configuration ?
Thanks
Vibhor said:
By definition of EPE, since energy of this configuration is negative then this means that when a unit test charge is brought from infinity towards the configuration, it experiences an attractive force.
Are you sure about this?
I might be wrong . EPE is electric potential per unit charge . Electric potential is work done in bringing a unit positive charge from infinity to a point . Since EPE is negative ,negative work is done , in which case the force is attractive from the configuration .
Please explain the mistake in my reasoning .
You confuse potential energy of a configuration with the potential around a configuration. The potential at a point P is the potential energy of a unit positive charge placed at that point. In this case, it can be both positive and negative. Far away, it is positive. Close enough to the negative charge, it is negative.
The potential energy of the configuration is equal to the work needed to make it. Negative energy means that energy is released when the three charges are brought into the positions given.
Likes Vibhor
o:) You are right .
In what manner is energy released when the charges are brought to their positions ?
Vibhor said:
o:) You are right .
The charge is attribute of material bodies. So those charges can be charged little balls, for example. If you fix the two positive ones, and release the negative one far away, along the symmetry axis of the other two, it will move towards the positive ones by itself, and the kinetic energy increases during its journey, When it is at d/2 position you catch it and fix it, but the KE is used up somehow. For example, you can stop it by a spring. Or it will hit a hole in your hand :)
Likes Vibhor
Thanks
In the problem statement, does electrostatic energy refer to the energy stored in the system, or the voltage?
I think the term "potential" may signify either potential energy or potential difference (voltage), depending on the context.
Yes !
Energy stored in the system.
Related to Electrostatic energy of three charges
1. What is electrostatic energy of three charges?
The electrostatic energy of three charges is the potential energy stored in a system of three charged particles due to their mutual electrostatic interactions. It is a measure of the work required to assemble the system of three charges from an infinite distance apart.
2. How is the electrostatic energy of three charges calculated?
The electrostatic energy of three charges can be calculated using the formula E = (k * q1 * q2) / r12 + (k * q2 * q3) / r23 + (k * q1 * q3) / r13, where k is the Coulomb's constant, q1, q2, and q3 are the charges of the three particles, and r12, r23, and r13 are the distances between the particles.
3. What is the relationship between the electrostatic energy and distance between the charges?
The electrostatic energy is inversely proportional to the distance between the charges. This means that as the distance between the charges increases, the electrostatic energy decreases, and vice versa.
4. How does the placement of the charges affect the electrostatic energy?
The placement of the charges can significantly affect the electrostatic energy. When the charges are close together, the electrostatic energy is high. However, when the charges are far apart, the electrostatic energy is low.
5. Can the electrostatic energy of three charges be negative?
Yes, the electrostatic energy of three charges can be negative. This occurs when the charges have opposite signs and are placed at a distance where the attractive force between them is greater than the repulsive force. In this case, the system has a lower potential energy compared to when the charges are infinitely far apart, resulting in a negative value for the electrostatic energy.
