Electrostatic FieldSchey's Notation
The notation is used to simplify the expression and avoid subscripts. In summary, the prime notation in the Electrostatic Field equation is used to represent the source dq and simplify the expression by avoiding subscripts.
Saladsamurai
3,020
Hey there,
I am just seeking some clarification wrt the notation that I have come across for the Electrostatic Field:
[tex]\mathvf{E}(\mathbf{r})=\frac{1}{4\pi\epsilon_0}\int\int\int_V\frac{\rho(\mathbf{r'})\hat{\mathbf{u}}(\mathbf{r'})}{|\mathbf{r}-\mathbf{r'}|^2}\,dV'[/tex]
So are all of the 'primes' just saying that the [itex]\rho,\hat{u}, dV[/itex] are simply those that correspond to the same location?
It seems like it is just a 'shorthand' notation to avoid a bunch of subscripts.
Is this correct?
Thanks,
Casey
All the "primes" are correspond to the source [tex]dq[/tex] of your (continuous) charge distribution, when [tex]\mathbf{r}[/tex] corresponds to the filed point, i.e. the point, where you want to find [tex]\mathbf{E}[/tex].
[tex]|\mathbf{r}-\mathbf{r'}|[/tex] is simply the distance between the source [tex]dq[/tex] and the field point [tex]\mathbf{r}[/tex].
Dear Casey,
Yes, you are correct. Schey's notation for the electrostatic field is a shorthand way of representing the integral expression for the electric field at a given point \mathbf{r}. The primes indicate that the variables \rho, \hat{\mathbf{u}}, and dV are evaluated at different locations within the volume V. This notation is commonly used in electromagnetism to simplify the expression and avoid excessive subscripts. It is important to note that the integral is still evaluated over the entire volume V, but the notation allows for a more concise representation. I hope this clarifies any confusion you may have had.
FAQ: Electrostatic FieldSchey's Notation
What is Electrostatic FieldSchey's Notation?
Electrostatic FieldSchey's Notation is a mathematical notation used to describe and calculate the electric field around a charged particle or set of particles.
Who developed Electrostatic FieldSchey's Notation?
Electrostatic FieldSchey's Notation was developed by physicist and mathematician John A. Schey in the 1960s.
What is the difference between Electrostatic FieldSchey's Notation and other notations for electric fields?
Electrostatic FieldSchey's Notation uses a different coordinate system, known as the Schey's coordinates, which simplifies the mathematical expressions for electric fields and makes them easier to work with.
How is Electrostatic FieldSchey's Notation used in practical applications?
Electrostatic FieldSchey's Notation is commonly used in the fields of electromagnetism, plasma physics, and particle physics to describe and calculate electric fields in various systems. It is also used in engineering and design of electric systems.
Is Electrostatic FieldSchey's Notation still relevant today?
Yes, Electrostatic FieldSchey's Notation is still used and relevant today in various fields of science and engineering. Its use has expanded beyond its original application in electrostatics to include other areas of physics and technology.
