Electrostatic force exerted on an electron inside a nucleus
In summary: So for ##r>R## you get$$[r \Phi(r)]''=0 \; \Rightarrow \; r \Phi(r)=C_1+C_2 r \; \Rightarrow \; \Phi(r)=\frac{C_1}{r} + C_2 \quad \text{for} \quad r>R.$$We can choose an arbitrary additive constant anyway freely, and it's convenient to choose it such that ##\Phi(r) \rightarrow 0## for ##r \rightarrow \infty##, i.e., we find$$\frac{C_1}{r}+C_
mangofan
TL;DR Summary
Why is the distance from the center of the nucleus not taken into consideration?
This is SAMPLE PROBLEM 25-7 from "Physics" by Resnik, Halliday, and Krane, in the chapter "Electric Field and Coulomb's Law".
After describing the behavior of uniformly charged spherical shells:
A uniformly charged spherical shell exerts no electrostatic force on a point charge located anywhere inside the shell.
A uniformly charged spherical shell exerts an electrostatic force on a point charge outside the shell as if all the charge of the shell were concentrated in a point charge at its center.
follows a sample problem:
SAMPLE PROBLEM 25-7. The spherical nucleus of a certain atom contains a positive charge Ze in a volume of radius R.
Compare the force exerted on an electron inside the nucleus at radius 0.5R with the force at radius R for a nucleus in which (a) the charge density is constant throughout its volume, and (b) the charge density increases in direct proportion to the radius r.
The solution to (a) goes to say that the volume inside R/2 is 1/8 of the total volume, therefore the charge is 1/8 of the total charge and finally the ratio of the forces F(R/2)/F(R) is 1/8.
Now this doesn't make complete sense to me. The electrostatic force is also inversely proportional to the distance between the charges. Taking that into account, F(R/2)/F(R) = 1/8 * 4/1 = 1/2. Am I missing something? I would be surprised for the book to contain such an obvious error.
Your reasoning looks correct to me. To be picky, the force between two point charges is inversely proportional to the square of the distance of separation. But you took the square into account in your reasoning. So, your conclusion is correct.
It is a bit surprising. Are you using a recently published edition?
Likes mangofan
Haliday and Resnick is a venerable textbook that has been around since 1960. "Adequately proofread" would probably be more appropriate than "recently published" in this case.
Likes mangofan
It's the 5th edition (the most recent) from 2002. Here is the complete text:
Thank you for posting that.
Whoever wrote that, assumed that 1/8 of the charge is at distance R not R/2.
Whoever proofread that, did not catch the mistake.
Likes mangofan, hutchphd, PhDeezNutz and 1 other person
See if that same example problem is included in earlier editions.
Also, do you know which printing you have of the 5th edition?
Likes mangofan
I've bought the book as new earlier this year and the pages look white, so it must have been printed quite recently. There's no info about a specific printing, the copyright section mentions 1960, 1962, ..., 1992, 2002.
Looking at the preface, it mentions that computing the force for a line of charge (volume of charge in the case above) was newly added in the 5th edition. There was no opportunity to fix the error.
You just have to solve for the electrostatic potential, which is very simple in these spherically symmetric examples. The potential is dependent only on ##r##, where the center of the spherical charge distribution is taken to sit at the origin of the coordinate system. In spherical coordinates you thus simply have to solve
$$-\Delta \Phi(r)=-\frac{1}{r} [r \Phi(r)]''=\frac{1}{\epsilon}_0 \rho(r),$$
which can be done by two integrations. The constants of these integrations are determined by the condition that there is no singularity at ##r=0##, if ##\rho## is continuous there, and that you can arbitrarily choose ##\Phi(r) \rightarrow 0## for ##r \rightarrow \infty##.
Likes mangofan
@vanhees71 , are you suggesting that more computation is needed and the answer for (1), constant charge density, is not ## \frac{F(R/2)}{F(r)} = \frac{1}{2}## as outlined above?
I don't know, what you are referring to here. The problems mentioned in the book are all of the form that you have a given spherically symmetric charge distribution ##\rho(r)## and want the electrostatic field everywhere. For that it's most easy to calculate the electrostatic potential, which by symmetry is a function of ##r## only (in spherical coordinates), i.e.,
$$-\frac{1}{r} [r \Phi(r)]''=\frac{1}{\epsilon_0} \rho(r).$$
The charge distribution is is assumed to vanish outside a sphere of radius ##R##, i.e., ##\rho(r)=0## for ##r>R##.
We can choose an arbitrary additive constant anyway freely, and it's convenient to choose it such that ##\Phi(r) \rightarrow 0## for ##r \rightarrow \infty##, i.e., we set ##C_2=0##. For the electric field you get there
$$\vec{E}=-\vec{\nabla} \Phi=\frac{C_1}{r^2} \vec{e}_r.$$
In the charge-free space you have a Coulomb field, and Gauß's Law tells you that for any spherical shell with a radius ##a>R## you have
$$\int_{S(a)} \mathrm{d}^2 \vec{f} \cdot \vec{E}=4 \pi a^2 E_r(a)=4 \pi C_1=\frac{Q}{\epsilon_0} \; \Rightarrow \ \; C_1=\frac{Q}{4 \pi\epsilon_0}.$$
For ##r<R## you have to integrate the above equation including the given ##\rho(r)## twice, i.e.,
$$[r \Phi(r)]'=-\int_0^r \mathrm{d} r' r' \rho(r')/\epsilon_0 + C_1',$$
and then
$$r \Phi(r)=-\int_0^r \mathrm{d} r'' \int_0^{r''} \mathrm{d} r ' r' \rho(r')/\epsilon_0 + C_1' r + C_2'$$
or
$$\Phi(r)=-\frac{1}{r} \int_0^r \mathrm{d} r'' \int_0^{r''} \mathrm{d} r ' r' \rho(r')/\epsilon_0 + C_1'+\frac{C_2'}{r} \quad \text{for} \quad r<R.$$
Now there are no singularities at ##r=0##, i.e., you must have ##C_2'=0##. Further there's no surface charge at ##r=R## in addition to the "bulk" charge distribution ##\rho(r)## for ##r<R##, and thus both ##E_r## and ##\Phi## are continuous at ##r=R##, from which you get ##C_1'##. For ##\vec{E}=E_r \vec{e}_r## you even don't need ##C_1'## at all.
Now take the first example,
$$\rho(r)=\rho_0=\frac{3 Q}{4 \pi R^3} \quad \text{f"ur} \quad r<R.$$
Then for ##r<R## you have
$$[r \Phi(r)]''=-\frac{\rho_0}{\epsilon_0} r \; \Rightarrow \; [r \Phi(r)]'=-\frac{\rho_0}{2 \epsilon_0} r^2 + C_1' \; \Rightarrow \; r \Phi(r)=-\frac{\rho_0}{6 \epsilon_0} r^3 + C_1' r.$$
Finally
$$\Phi(r)=-\frac{\rho_0}{6 \epsilon_0} r^2 + C_1'=-\frac{Q}{8 \pi \epsilon_0 R^3} r^2+C_1' \quad \text{for} \quad r<R.$$
For the electric field you thus get
$$E_r=-\Phi'(r)=\begin{cases} \frac{Q}{4 \pi \epsilon_0 R^3} r & \text{for} \quad r<R, \\ \frac{Q}{4 \pi \epsilon_0 r^2} & \text{for} \quad r \geq R, \end{cases}$$
and indeed ##E_r## is continuous at ##r=R##, as already argued about above.
The 2nd example, where ##\rho=C r## for ##r<R## you can try to solve for yourself. It's a good exercise!
Likes mangofan
This sample problem is from chapter 25 of the text, which is the first chapter dealing with electricity and magnetism. The concepts of electric field and electric potential are introduced in later chapters. The tools available to solve the problem are Coulomb's law and the "shell theorem". The shell theorem is stated in the text (without derivation) a few paragraphs before the sample problem.
Likes nasu and mangofan
Thanks @vanhees71 for the explanation and @TSny for the clarification.
Indeed, if we take the final formula where ##E_r \propto r##, we get ## \frac{F(R/2)}{F(R)} = \frac{1}{2}##, the same result as Coulomb's Law for the equivalent point charge.
Likes SammyS and TSny
The posted wrong solution impies that, instead of using ##\mathbf{F}=q\mathbf{E}## for the Coulomb force on the charge, the expression ##~\mathbf{F}=q \int_s \mathbf{E}\cdot\hat n~dA~## was effectively used. Here is why. $$\begin{align}
&F(R)=q \int_{S_1} EdA=\frac{q}{\epsilon_0}\int_0^R~\rho(r)dV \nonumber \\
& F(R/2)=q \int_{S_2} EdA=\frac{q}{\epsilon_0}\int_0^{\frac{R}{2}}~\rho(r)dV \nonumber \\
&\implies \frac{F(R/2)}{F(R)}=\frac{\int_0^{\frac{R}{2}}~\rho(r)dV}{\int_0^R~\rho(r)dV}.\nonumber
\end{align}$$The expression erroneously gives the ratio of the forces as the ratio of enclosed charges.
kuruman said:
The posted wrong solution impies that, instead of using ##\mathbf{F}=q\mathbf{E}## for the Coulomb force on the charge, the expression ##~\mathbf{F}=q \int_s \mathbf{E}\cdot\hat n~dA~## was used.
Maybe. But this seems strange to me. The incorrect expression ##~\mathbf{F}=q \int_s \mathbf{E}\cdot\hat n~dA~## is not even dimensionally consistent.
Likes nasu
Look at the row of numbers at the bottom of the book's copyright page. The lowest number in the series is the number of the book printing. Each time a new printing is made known errors get corrected. You will sometimes find that even though you and your classmates and your professor all have the same edition, there will be slight differences due to different printings of the same edition.
I found a copy of the 5th edition in Spanish with a copyright date of 2002 and a printing date of 2007. It has the same error. So, the error has been around for quite a while.
Here is the copyright page. @Mister T , are you referring to the "10" on the bottom of the page?
A common complaint is "Harumph! The publishers change editions too often!" Another common complaint is "Harumph! The errors never seem to get corrected!"
:smile:
The solutions manual in particular has and has always had a number of mistakes.
  • Haha
Likes vanhees71
:smile:
Exactly! The errors never seem to be corrected because the publishers change editions too often. :olduhh:
  • Haha
Likes vanhees71 and malawi_glenn
Yes. You have the 10th printing.
Likes mangofan
Related to Electrostatic force exerted on an electron inside a nucleus
What is the electrostatic force exerted on an electron inside a nucleus?
The electrostatic force exerted on an electron inside a nucleus is the force of attraction between the negatively charged electron and the positively charged protons in the nucleus. This force is described by Coulomb's law, which states that the force is directly proportional to the product of the charges and inversely proportional to the square of the distance between them.
Why is it unusual to consider an electron inside a nucleus?
It is unusual to consider an electron inside a nucleus because, according to quantum mechanics and the principles of atomic structure, electrons typically occupy orbitals outside the nucleus. The nucleus is composed of protons and neutrons, and the energy levels of electrons are such that they do not reside within the nucleus under normal conditions.
How does the electrostatic force inside the nucleus compare to the force outside the nucleus?
Inside the nucleus, the electrostatic force would be extremely strong due to the close proximity of the electron to the protons. However, in reality, electrons do not exist inside the nucleus under normal atomic conditions. Outside the nucleus, the electrostatic force is weaker because the distance between the electron and the nucleus is greater, following the inverse-square law of Coulomb's force.
Can an electron actually exist inside a nucleus?
Under normal atomic conditions, an electron cannot exist inside a nucleus due to the principles of quantum mechanics and the Pauli exclusion principle. However, in certain high-energy processes, such as electron capture in nuclear reactions, an electron can be absorbed by the nucleus, but this is a rare and specific event.
What role does the electrostatic force play in nuclear reactions involving electrons?
In nuclear reactions involving electrons, such as electron capture, the electrostatic force plays a crucial role in drawing the electron close to the nucleus, allowing it to be captured by a proton, which then transforms into a neutron. This process changes the composition of the nucleus and is a key mechanism in certain types of radioactive decay.
