Electrostatics Deflection Problem
In summary, an inkjet printer works by rapidly moving a nozzle to squirt ink drops onto paper to form letters and images. However, common problems such as horizontal white lines and malfunctioning can occur due to a clogged nozzle or paper dust. In terms of electrostatics, paper dust can interfere with the movement of charged ink drops, causing the printer to malfunction. In the second part of the problem, the drops are given a positive charge by a charging unit and then pass between parallel plates with a uniform electric field. By applying relevant equations, the magnitude of the charge acquired by each drop can be determined.
Callix
106
In inkjet printing, a rapidly moving nozzle horizontally squirts drops of ink that form letters and images on paper. A common problem is horizontal white lines running through the print due to a clogged nozzle. Another common problem is paper dust.
(a) Within the context of electrostatics, explain why paper dust can cause an inkjet printer to malfunction.
(b) Suppose the ink drops have a mass m = 2.00 x 10^-11 kg each and suppose the magnitude of the velocity at which they horizontally travel is 30 m/s. The drops pass through a charging unit that gives each drop a positive charge q by causing it to lose some electrons. The drops then pass between parallel deflecting plates of length D = 2.20 x 10^-2 m, where there is a uniform vertical electric field with magnitude E = 8.6 x 10^4 N/C. If a drop is deflected a distance d = 3.30 x 10^-3 m, what magnitude of charge q does each drop acquire by the time it reaches the end of the deflection plate? The density of ink is 1,000 kg/m^3; assume the effects of gravity are negligible.
Possible relevant equations
y(t) = 1/2at^2
x(t) = vt
E = kQq/r^2
F = qE = ma
The attempt at a solution
(a)
. My thought process for this question was that there is a possibility that the dust particles are also charged in some manner. Therefore, the movement of these other outsider charges causes interference with the printer.
(b). I'm having a hard time picturing the drop passing through a charging unit and the deflection that occurs between the two parallel plates. I tried to look up diagrams in my textbook that depict a similarly described scenario, but there was nothing relevant. I also have a feeling that I'm going to have to apply some kinematic equations to also be able to solve part of this question.
Any help would be greatly appreciated! :)
This problem has been solved :)
Related to Electrostatics Deflection Problem
What is electrostatics deflection problem?
Electrostatics deflection problem is a scientific concept that deals with the behavior of electrically charged particles in an electric field. It involves calculating the deflection or movement of these particles based on the strength and direction of the electric field.
What are some real-world applications of electrostatics deflection?
Electrostatics deflection has several real-world applications, including CRT televisions, inkjet printers, and particle accelerators. It is also used in the design of electronic devices and in analyzing the behavior of charged particles in space.
What factors affect the deflection of charged particles in an electric field?
The deflection of charged particles in an electric field is affected by several factors, including the strength and direction of the electric field, the charge and mass of the particle, and the distance between the particle and the electric field source.
How is the deflection of charged particles calculated in electrostatics deflection problem?
The deflection of charged particles in electrostatics deflection problem is calculated using the Coulomb's law, which states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
What are some common misconceptions about electrostatics deflection problem?
One common misconception about electrostatics deflection problem is that it only involves the movement of positively charged particles. However, both positively and negatively charged particles can be deflected in an electric field. Another misconception is that the deflection is instantaneous, but it actually takes time for the particles to respond to the electric field.
9K
