Electrostatics problem: Find charges on the surface of the dielectric
The discussion focuses on determining the induced charges on the surfaces of a dielectric surrounding a charged object. The initial approach using Gauss's law led to confusion regarding the relationship between electric flux inside and outside the dielectric. Participants clarified that charge cannot flow through a perfect insulator, and the effect of the dielectric's permittivity on induced charge was emphasized. The relationship between the relative permittivity and induced charge was explained, noting that the induced charge is proportional to the dielectric's response to the electric field. Ultimately, the correct formula for induced charge was confirmed, enhancing understanding of the problem.
Sunil Simha
An arbitrarily-shaped object is given a charge q and is then surrounded by a dielectric of permittivity ε as shown in the figure below
Find the charges induced in the inner and outer surface of the dielectric.
I'm not sure but Gauss's law may be relevant here somehow.
I initially thought that electric flux inside the dielectric would be the same as that outside the dielectric. So assuming -q' to be the charge on the inner surface, I got \frac{q-q'}{ε}=\frac{q}{ε_0}. But upon reflection, I realized that this is wrong because
q-q'<q
\frac{1}{ε}<\frac{1}{ε_0}
and therefore \frac{q-q'}{ε}<\frac{q}{ε_0}.
Could you please help me by telling me how to approach the problem or how to make a right start.
Thanks in advance.
Sunil
Not sure, but it may be a trick question, as charge can't actually flow through a perfect insulator (insulator and dielectric tended to be interchangeable when I took this).
If not, I think this may be relevant:
http://en.wikipedia.org/wiki/Permittivity#Explanation
According to the equation I see there, "how much" the dielectric responds to the E field is proportional to relative permitivity of the dielectric.
It's easier to explain with a parallel plate capacitor. If you place a dielectric in between the two plates the field inside will be weakened. If the dielectric has a relative permittivity ε_r of 2 that means the charge induced on the surface of that dielectric is 1/2 of that of the plates. That charge than produces a field of it's own that partially cancels out the field of the plates. If ε_r = 3 the induced charge will be 2/3 of q meaning the field inside is reduced to 1/3. So in general the charge induced on the dielectric is q*(ε_r - 1)/ε_r
Likes gracy
Thanks a lot. I got it now. :smile:
