Electrostatics problem- two sphere
In summary: If there is no electric field between the spheres then there can be no potential gradient between them. However, if there is no potential gradient then the spheres must carry the same potential.
Physgeek64
247
A spherical capacitor comprises two thin metal spheres of different radii but with
a common centre. The following series of operations is completed: The spheres are mutually connected by an internal wire. The outer sphere is raised to potential +V with respect to ground. The internal connection is broken. The outer sphere is returned to ground potential. Determine the final potential and the final charge on the inner sphere
Gauss' law
So initially when both spheres are raised to a potential V, no potential gradient exists across the two spheres, and hence no electric field can exist. So by Gauss' law the charge enclosed, ie. on the inner sphere, is zero. When the connection is broken and the outer sphere is returned to ground the charge will still be zero. But then this automatically implies that the potential must be zero? So no potential or charge resides on the inner sphere.
Does this sound reasonable? My only concern is that the inner sphere must maintain the same potential as the outer during the entire discharge process, or else an electric field would exist between them, which would not be consistent?
Many thanks :)
... you may want to expand on this reasoning. It is correct, but you have not explained it.
My only concern is that the inner sphere must maintain the same potential as the outer during the entire discharge process,..
That is not what the problem statement says.
(Note: a "two sphere" is a circle ... your problem involves "two spheres" - the "s" on the end indicates a plural so the reader realizes there is more than one object.)
But if there exists no electric field between the two spheres at any point then there can be no potential gradient between them at any point. But this would suggest that they always carry the same potential?
And sorry- my mistake (typo)
Try expressing in terms of the movement of charge.
Related to Electrostatics problem- two sphere
1. What is an electrostatics problem involving two spheres?
An electrostatics problem involving two spheres is a problem that deals with the behavior of electric charges on two spherical objects in close proximity to each other. This can include questions about the electric fields, forces, and potentials between the two spheres.
2. How do you solve an electrostatics problem involving two spheres?
To solve an electrostatics problem involving two spheres, you can use the principles of Coulomb's Law and Gauss's Law to calculate the electric fields, forces, and potentials between the two spheres. You may also need to use concepts such as electric potential energy and electric dipoles to fully solve the problem.
3. What are the key assumptions made in solving an electrostatics problem involving two spheres?
The key assumptions made in solving an electrostatics problem involving two spheres are that the spheres are perfectly conducting, the charges are stationary, and the problem can be treated as a two-dimensional system. These assumptions allow for simpler mathematical calculations and provide accurate solutions for many practical scenarios.
4. How do the properties of the two spheres affect the electrostatics problem?
The properties of the two spheres, such as their size, charge, and distance from each other, directly affect the electric fields, forces, and potentials between them. For example, larger spheres with higher charges will have stronger electric fields and forces between them, while increasing the distance between the spheres will decrease the strength of the fields and forces.
5. What are some real-life applications of electrostatics problems involving two spheres?
Electrostatics problems involving two spheres have many real-life applications, including in the design of capacitors, the behavior of charged particles in a particle accelerator, and the study of lightning and thunderstorms. These problems also have practical applications in industries such as electronics, aerospace, and energy production.
