Element of surface area in spherical coordinates
In summary: Formulas: dS=2πrsinθ\sqrt{dr^2+r^2dθ^2}This expression is derived from the equations ##dV=\frac{1}{2}\cos(\theta)## and ##dx\wedge dy\wedge dz=0##.
cdot
45
In spherical polar coordinates, the element of volume for a body that is symmetrical about the polar axis is,
$$\begin{equation}
dV=2\pi sin{\theta} dr d\theta
\end{equation}$$
Whilst its element of surface area is,
$$\begin{equation}
dS=2\pi rsin{\theta} \sqrt{dr^2+r^2d\theta^2}
\end{equation}$$
Although the homework statement continues, my question is actually about how the expression for dS given in the problem statement was arrived at in the first place.
This question is at the end of a chapter covering multiple integrals, including a change of variables in multiple integrals where, for a change of variables from Cartesian coordinates to spherical polar coordinates, we have,
$$\begin{equation}
dxdydz = Det[J] dr d\phi d\theta = r^2 sin\theta dr d\phi d\theta
\end{equation}$$
Where ## Det[J]## is the determinant of the 3x3 Jacobian Matrix containing all the partial derivatives of ##x,y,z## with respect to ##r,θ,ϕ##
r,θ,ϕ
For integration over the ##x y plane## the area element in polar coordinates is obviously ##r d \phi dr ## I can also easily see ,geometrically, how an area element on a sphere is ##r^2 sin\theta d\phi ## And I can verify these two cases with the Jacobian matrix. So that's where I'm at. That's what I know. However, trying to take the determinant of the Jacobian in this case obviously does not get me the expression given in the problem statement and I'm not sure where to begin. Thank you for your help. I'm not actually in school but looking to go back for Physics and don't have any teacher to turn to.
Just realized I forgot the ##d\theta## in the area element on a sphere ##(dS=r^2sin\theta d\phi d\theta) ##
What's the surface element in Cartesian coordinates?
Doesn't it depend on the surface? If you're integrating over x-y plane its just dxdy
I don't see how that helps me though
My question is actually about how the expression for dS given in the problem statement (##dS=2πrsinθ\sqrt{dr^2+r^2dθ^2}##) was arrived at in the first place, given the equations stated above (which was all that we were assumed to know as of attempting this problem). The only example problems up to this point involved computing Jacobians to make a change of variables in multiple integrals. A basic example of such a transformation would be how the volume element in cartesian coordinates ##dxdydz## transforms to ##r^2 sin\theta dr d\theta d\phi## where ##r^2 sin\theta## is the determinant of the Jacobian matrix. The area element on a sphere can be found by similar means, but can also be arrived at geometrically: ##dS=r^2 sin\theta d\theta d\phi## But this type of procedure would never lead me to the expression given in the problem statement. I can see how, for a problem with symmetry about the polar axis (like this one) the phi part of the integral would just integrate to ##2\pi ## (the leading factor in the given area element expression). So I expected something of the form ##2 \pi (something) dr d\theta##. Since the surface I'm integrating over may not necessarily be on a sphere, the dr makes an appearance this time. ##2\pi (something) dr d\theta## needs to be an area. An area is a displacement time a displacement. ##dr## is a displacement itself (its scale factor is one). To convert the infinitesimal change in ##\theta## to a displacement, it needs to be multiplied by a scale factor. Well, I thought, multiplying by r would do that. So my conclusion is that an area element (for an arbitrary body with symmetry with respect to ##\phi## which leads to the ##2\pi## factor) should be ##2\pi r d\theta dr ##. On comparison with the area element in the problem statement, this leads me to the conclusion that ##d\theta dr = sinθ \sqrt{dr^2+r^2 dθ^2}## which I cannot reconcile and that's annoying because I know somewhere I'm being stupid and my reasoning is faulty. That's why I made my way to PF and spent way too much time on this question. I really appreciate the time and help. I will be sure to pay it forward at some point. One clue I've picked up on for my question is that the square root factor in the expression is the magnitude of a general displacement vector in spherical coordinates (where the phi component is zero). That's all I've got. Hopefully this essay clarifies my question a little more. Thanks again
From where, given what? What is ##S## in this specific case?
... in the first place, given the equations stated above ...
Which equations? ##dV## or ##dx\wedge dy\wedge dz##?
Just answer these few questions: formulas, no essays.
Related to Element of surface area in spherical coordinates
1. What is the definition of element of surface area in spherical coordinates?
The element of surface area in spherical coordinates is a small surface area on a sphere that is defined by two angles, θ and φ, and a small change in these angles, dθ and dφ, respectively. It is used to measure the surface area of a curved object, such as a sphere, in three-dimensional space.
2. How is the element of surface area calculated in spherical coordinates?
The element of surface area in spherical coordinates is calculated using the formula dS = r² sinθ dθ dφ, where r is the distance from the origin to the surface point, θ is the polar angle, and φ is the azimuthal angle. This formula takes into account the curvature of the surface and the change in the angles.
3. What is the relationship between element of surface area and solid angle in spherical coordinates?
The element of surface area is directly related to the solid angle in spherical coordinates. The solid angle is defined as the ratio of the element of surface area to the square of the distance from the origin to the surface point, while the element of surface area is the product of the solid angle and the square of the distance from the origin to the surface point.
4. How does the element of surface area change as the radius of the sphere increases in spherical coordinates?
As the radius of the sphere increases in spherical coordinates, the element of surface area also increases. This is because the surface area of a sphere is directly proportional to its radius. Therefore, as the radius increases, the surface area also increases, resulting in a larger element of surface area.
5. Why is the element of surface area important in spherical coordinates?
The element of surface area is important in spherical coordinates because it allows us to measure the surface area of curved objects in three-dimensional space. This is particularly useful in fields such as physics, engineering, and astronomy, where many objects have curved surfaces and the element of surface area is needed for calculations and analyses.
