Elementar question about steering
  • Thread starter Vincent Mazzo
  • Tags
    Steering
In summary, camber and slip angle both play important roles in a vehicle's handling and cornering power. Slip angle is the angle between the tire's rolling direction and the direction of travel, and can affect a vehicle's stability and response. Camber, on the other hand, creates a lateral force on the tire and helps with steering and stability. Both concepts are further explained in Ranger Mike's thread on Race Car Suspensions Class.
Vincent Mazzo
Hello guys.
My question is: what is the purpose of camber and slip angle? It's only to create an align torque on the wheel?
Thx all
Slip angle should be the angle between your tire's rolling direction and your path of travel. Large factor in cornering power involving numerous factors.
Camber is for establishing a quality of handling of a vehicle.
You should be able to get a good explanation of both of these in Ranger Mike's thread in Race Car Suspensions Class.
There is no «purpose» for the slip angle. It is an observed reaction when a lateral force is applied to the tire.
As for camber, it creates a lateral force on the tire (just like steering angle or toe). So if a tire has camber, it is like the tire is already steered, hence it can react quicker, it is more responsive. Also, as the wheel goes up, we try to have camber gain because - usually - the greater the roll angle, the greater the lateral acceleration, thus the greater the lateral force needed. By having increased camber with roll angle, the car has a tendency to «correct» itself, making it a more stable vehicle.
Related to Elementar question about steering
1. What is steering?
Steering is the process of controlling the direction and movement of a vehicle or object. It involves using a steering mechanism, such as a steering wheel, to turn the front wheels or rudder of a vehicle to change its direction.
2. How does steering work?
Steering works by using a steering mechanism, such as a steering wheel, to turn the front wheels or rudder of a vehicle. This movement is transmitted through a series of mechanical parts, such as steering columns, linkages, and joints, to control the direction and movement of the vehicle.
3. What are the different types of steering systems?
There are several types of steering systems, including rack and pinion, recirculating ball, and worm and sector. These systems use different mechanisms to convert the rotation of the steering wheel into movement of the front wheels or rudder.
4. How does power steering work?
Power steering is a type of steering system that uses hydraulic or electric power to assist with turning the front wheels or rudder. It works by using a pump to apply pressure to the steering mechanism, making it easier for the driver to turn the steering wheel.
5. What factors affect steering?
Several factors can affect steering, including the type of steering system, the condition of the steering components, the weight and distribution of the vehicle or object being steered, and external factors such as road conditions and wind. These factors can impact the responsiveness and stability of the steering system.
  • Mechanical Engineering
  • DIY Projects
  • Classical Physics
  • Classical Physics
