MHB Elementary Algebraic Geometry: Dummit & Foote Ch.15, Ex.24 Coordinate Ring
The discussion focuses on understanding Exercise 24 from Dummit and Foote's Chapter 15 on elementary algebraic geometry, specifically regarding the nature of k-algebras and the properties of the variety defined by the equation xy - z². Participants highlight that the variety resembles a cone in affine 3-space and is singular at the origin, contrasting with the smoothness of A². A key argument presented is that if the coordinate rings of the varieties were isomorphic, it would lead to a contradiction regarding their irreducibility and properties as principal ideal domains. This illustrates the complexities involved in determining the isomorphism between varieties and their corresponding coordinate rings. The conversation emphasizes the importance of understanding these algebraic structures to tackle the exercise effectively.
Math Amateur
MHB
I am trying to gain an understanding of the basics of elementary algebraic geometry and am reading Dummit and Foote Chapter 15: Commutative Rings and Algebraic Geometry ...
At present I am focused on Section 15.1 Noetherian Rings and Affine Algebraic Sets ... ...
I need help to get started on Exercise 24 of Section 15.1 ...Exercise 24 of Section 15.1 reads as follows:https://www.physicsforums.com/attachments/4763***NOTE***
I do not really fully understand the nature of a k-algebra ... so any help in making the notion of an algebra clearer will help ... as well as a significant start on the exercise ...Hope someone can help ...
Peter
You should be able to do the first part of the exercise as I have already given hints in the other thread.
For the second part, I really don't see how you can do this without some machinery. $\mathcal{Z}(xy - z^2)$ looks like a cone in the affine $3$-space, if you try to draw it. You can try and you will convince yourself that the variety at $(0, 0, 0)$ is singular, while $\Bbb A^2$ is smooth everywhere. The formalization of this is that the Zariski tangent space of the variety at $(0, 0, 0)$ is a vector space of dimension $3$, whereas dimension of the variety is of dimension $2$. Thus, $\mathcal{Z}(xy - z^2)$ is not smooth, and hence cannot be isomorphic to $\Bbb A^2$.
EDIT : OK, figured out how to do this without fancy arguments. This one is tricky. Assume that $\mathcal{Z}(xy - z^2)$ is isomorphic to $\Bbb A^2$. Then the coordinate rings $k[x, y, z]/(xy - z^2)$ and $k[u, v]$ are isomorphic as affine $k$-algebras. This implies they must also be isomorphic as rings. But note that in $k[x, y, z]/(xy - z^2)$, $x, y, z$ are irreducible elements, but since $x \cdot y = z \cdot z$, it cannot be a P.I.D. But $k[u, v]$ is a P.I.D., contradiction.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
