Elementary processes in Feynman Diagrams
In summary, the author is struggling to understand how to correctly draw Feynman diagrams for simple reactions. They've been reading books and classes, but have some unanswered questions. They've attached their notes with questions clearly marked, in the hopes that the author can answer them. Energy and momentum are conserved at every vertex, and the diagram is a graphical way to display perturbative calculations. There are things that do not have a proper Feynman diagram, and the author has questions about whether energy and momentum are conserved when virtual particles are involved.
Xico Sim
43
Hello there.
I'm attending an introductory course in particle physics. We're supposed to know how to draw first-order tree level Feynman diagrams for simple reactions.
I've been struggling to understand the method I should follow in order to correctly draw them.
As I understand it now, we can combine the elementary vertexes of each interaction to get any possible diagram.
Starting from what I've learned by reading Griffiths' book and from my classes, I tried to write some notes about this, and found out that I have some unanswered questions about it.
I attached my pdf file with my notes, with the questions clearly identified in boxes - everything inside a box is a question.
If you could please answer some of those and perhaps see if I got the concepts right, I'd be very grateful.
  • Feynamn_Diagrams.pdf
There are things that cannot be calculated with perturbation theory, and Feynman diagrams are a graphical way to display perturbative calculations. There are things that do not have a proper Feynman diagram.
Mesons are not fermions.
> Are there variants other than rotations?
Depends on what exactly you count as rotation, but as long as that vertex is present it is fine.> In this case, the gluon will be blue and anti-red
If you want to assign colors like that, the gluon should also have a clear time-direction in the diagram (here: outgoing). This also applies to the W discussed later.
You are missing the gluon self-interaction and the vector boson couplings.
Diagram (7) is not the same as (6), but if you mirror/rotate it in time and then replace particles by antiparticles you get 7 from 6.
Why is there no tree-level neutral flavor changing process? That is a very good question, we just do not observe it.
Energy and momentum are conserved at every vertex.
> Is isospin, parity, charge conjugation and avor conserved in QCD vertexes??
Yes.
Likes Xico Sim
  • By rotation I meant only proper rotations... Reflections are also fine? If they are, do the (proper+improper) rotations of the drawn vertex generate all possible vertexes? And what do you mean by "as long as the vertex is present"?
  • About the arrows in the gluon and the W bosons: I know, but I couldn't get Lyx to render the arrows, I don't know why. I'll fix that later.
  • I thought the self-interactions were unimportant for 1st order diagrams...
  • Energy and momentum are conserved at every vertex? But if we consider the elementary QED vertex and consider the CM reference frame, we have ##E_i = mc^2## but ##E_f=mc^2+E_\gamma##, meaning that ##E_i \neq E_f## Besides, there are problems with conservation of momentum too if we consider the vertex corresponding to the electron-positron annihilation, obtained by rotating the elementary QED vertex. Griffiths says something about this too, and so I understood that energy and momentum are not conserved when virtual particles are involved (in single vertexes), but only when we talk about whole processes... am I wrong
Thank you for your answer, by the way. I'm learning a lot!
Up and down do not have a meaning, so a reflection is the same as a rotation by 180 degrees.
2 fermions and a photon coupling to each other, with conserved quantum numbers. It does not matter in which direction the individual legs point.
1st order of what in what? For fermion interactions, yes. For boson interactions, no.
Well, it tells you that this process on its own is not physical, you need a second vertex to produce an actual interaction. At least one of the particles won't satisfy the usual energy/momentum relation. Electron-positron annihilation cannot go to a single photon for the same reason. Add another photon at a second vertex and you can conserve energy and momentum at both vertices.
Fair enough.
Ok.
I'm not sure: in my course we don't really get to understand what the Feynman Diagrams are, so it's all very superficial. Sadly, I must (for now) just find a recipe to follow.
As I understand, the total process does conserve energy and momentum, but not each vertex. I did not understand how what you said goes against that.
I will post an update of my pdf now. I think I got all EM vertexes right.
Energy and momentum are conserved exactly at each vertex.
Don't think of them as 6 separate things, they are the same interaction.
The energy and momentum have to be conserved exactly at each vertex...
At the vertex of the lower right Fig9 of your plot for example, you can say that [itex]\bar{a}[/itex] has energy and momentum [itex]E_1,\vec{p}_1[/itex] and the [itex]a[/itex] has [itex]E_2, \vec{p}_2[/itex]... then the photon you write should have energy and momentum [itex]E_\gamma = E_1+E_2[/itex] and momentum [itex]\vec{p}_\gamma = \vec{p}_1 + \vec{p}_2[/itex].
This is energy/momentum conservation at each vertex...
What may be true though is that the photon is off-shell, meaning that it doesn't obey the [itex]E^2_\gamma - | \vec{p}_\gamma|^2 = m^2_\gamma = 0[/itex] relation... In that case it can't appear as a physical particle in the final state but needs to be connected to another vertex.
Likes Xico Sim
But how can momentum be conserved in the process I mentioned above? (Electron goes to electron plus photon)
Point 1 to your above mentioned process: the [itex]E_\gamma =0 [/itex] allows the conservation of energy and momentum. Meaning that the photon carries no energy but momentum...
Point 2 to your above process: the photon in that case is off-shell, as mfb said it doesn't satisfy the known energy/momentum relation [itex]E_\gamma^2 - | \vec{p}_\gamma|^2 =m^2_\gamma =0[/itex].. This means that you don't observe it but it has to be connected to some other vertex to have the complete interaction...If you do so then of course it can happen, an electron scattering off some other charged particle is done with such a vertex.
Likes Xico Sim
So we can think of virtual partiicles as having no energy? Always?
Even so, the conservation of momentum in my example is still impossible, right?
No. Virtual particles are particles that donnot obey the energy/momentum relation... they can have 0 energy and momentum, they can have energy and 0 momentum, and of course they can have both energy and momentum but their combination/4momentum squared is not equal to the physical particle's mass. The particle cannot be observed and has to be connected to another vertex... by the way, a vertex itself hardly ever shows an "interaction".
Why? In fact it's not right, since by construction vertices conserve both energy and momentum.
May I also ask which phrase you misinterpret as stating that momentum or energy are not conserved at a vertex?
That process on its own is not physical - it does not happen.
Let me try to me clear, here.
I know that the process "Electron goes to electron plus photon" does not happen. In fact, it couldn't happen, it does not conserve momentum or energy.
This is precisely the reason why I'm saying that vertexes don't conserve energy or momentum: this example corresponds to a vertex but violates conservation of energy and conservation of momentum!
Not exactly one phrase, but this whole argument: all I was saying was:
Look! Here is a vertex which represents a process which does not conserve energy or momentum! It doesn't matter if this process is physical or not: I'm only asking if p and E are conserved, and the answer is "no".
Let me put this differently: In the afore-mentioned process (and in the CM frame), the total initial energy is mec². The final energy is ##m_{e}c^2+E_\gamma##. Therefore, E is conserved is conserved iff ##E_\gamma=0##. Momentum conservation raises no problems.
About the process ##e^- + e^+ \rightarrow \gamma##: Energy conservation raises no problems. Momentum is conserved iff ##p_e=0## and ##p_\gamma=0##.
That said, I know realized that the first process conserves energy only if the photon has no energy, whereas the second one conserves momentum only if the photon has no momentum. Are you saying that, for some reason, this is allowed?
It would have to violate it, if that vertex would be a physical process. This vertex is not a physical process - your argument about outgoing particles does not apply, because at least one of those lines does not correspond to an actual particle, and the energy/momentum relation for that line will not follow the usual relation from special relativity.
In the center of mass frame of the electron/positron you don't have to impose [itex]p_e=0[/itex].. just for the photon [itex]p_\gamma=0[/itex] is enough... In any other reference frame, the photon can still have other momenta [itex]\vec{p}_\gamma= \vec{p}_{e^-} + \vec{p}_{e^+}[/itex]...
I am not also saying it is allowed, I am saying that by construction [and what mathematically vertices represent] energy/momentum are conserved at each vertex... you would have a non-conservation if you couldn't deduce the energy/momentum of the photon by the energy/momenta of the electron and positron... Whether then the process is possible or not, depends on whether your "final state particle" is on-shell (real) or not (virtual)... A virtual particle cannot be a final state because they don't get observed... Especially depending on how off-shell the particle is, the "faster" (if that would make sense) it decays...If you get pretty close to the particle's mass ([itex]E^2_x - p^2_x \approx m_x^2[/itex], then it can also act as a resonance...
For example the [itex]e^- e^+ \rightarrow \gamma[/itex] is not observable... the [itex]e^- e^+ \rightarrow \gamma \gamma[/itex] is.
The interaction [itex]e^- e^- \rightarrow \gamma \rightarrow \mu^- \mu^+[/itex] is allowed (given that the electrons have enough energy to produce the heavier muons) and in both vertices ([itex]e^-e^+\gamma[/itex] and [itex]\mu^- \mu^+ \gamma[/itex]) separately the energy/momentum is conserved.
I think a lot of the problems people have with QFT and Feynman diagrams is that they got from some popular-science sources the wrong idea that Feynman diagrams are pictures for processes in the real world. In a certain sense it's true, but only in a certain sense!
Feynman diagrams are not pictures of how physicists think that scattering processes really happen but they are symbols for mathematical expressions to calculate S-matrix elements. E.g., the QED vertex (electron-positron-photon vertex) stands for ##\mathrm{i} e \gamma^{\mu}## (the ##\mu## is the Lorentz index carried by the photon line).
Then there are rules to define the meaning of the Feynman diagrams when you evaluate an S-matrix element, i.e., transition-rate amplitudes for the real processes observable in nature. Let's now just take the above mentioned vertex and consider it as a real processes. Drawing the photon line pointing down and the electron and positron lines pointing up, this would be the S-matrix element for the decay of a photon to an electron-positron pair (time conventionally running from bottom to top). Now the Feynman rules tell you that external lines stand for wave functions of asymptotic free particles, i.e., the momenta of external lines must fulfill the on-shell condition ##p \cdot p=m^2## for each of the lines with ##m## being the invariant mass of the corresponding particle. Further on each vertex energy-momentum conservation must be fulfilled. Analysing this with the "photon decay" we consider here, you'll see that you cannot fulfill the on-shell conditions together with energy-momentum conservation. That's understandable, because for a particle to decay into two other particles it must have a mass bigger than the sum of the masses of the decay products ("threshold" for decay). Since the photon mass is 0, it cannot decay to anything. So also interpreting the elementary vertex as a real process leads to the correct result that a photon cannot decay into an electron-positron pair. Of course the same holds if you arrange the diagram to describe the decay of an electron to a positron and a photon or a positron decaying into an electron and a photon. For none of these processes you can fulfill the kinematical constraints (on-shell conditions and energy-momentum conservation), and thus all these processes do not happen.
Related to Elementary processes in Feynman Diagrams
1. What are Feynman diagrams?
Feynman diagrams are graphical representations used in theoretical physics to describe interactions between elementary particles. They were developed by Nobel Prize-winning physicist Richard Feynman in the 1940s.
2. What is the purpose of using Feynman diagrams?
The main purpose of Feynman diagrams is to provide a visual representation of the complex mathematical equations that govern particle interactions. This allows scientists to better understand and predict the behavior of particles at the quantum level.
3. How are Feynman diagrams used to study elementary processes?
Feynman diagrams are used to study elementary processes by representing the interactions between particles as lines and vertices. These diagrams can be manipulated using rules and calculations to determine the probability of different outcomes for a given process.
4. What are the elementary processes in Feynman diagrams?
The elementary processes in Feynman diagrams include the emission, absorption, and scattering of particles, as well as the creation and annihilation of particle-antiparticle pairs.
5. How do Feynman diagrams contribute to our understanding of the universe?
Feynman diagrams have played a crucial role in our understanding of the universe, particularly in the field of particle physics. They have been used to predict the existence of new particles, explain the behavior of subatomic particles, and support the Standard Model of particle physics.
