Elementary question on composition of functions
In summary, composition of functions is an operation that combines two or more functions to create a new function. To evaluate a composition of functions, you need to identify the inner and outer functions, substitute the input value into the inner function, and simplify the expression. The composition of functions differs from the product of functions as it uses the output of one function as the input for the other, while the product multiplies the functions together using the same input value. Not all functions can be composed, as the output of the inner function must be in the domain of the outer function. The associative property of composition of functions states that the order in which functions are composed does not matter.
facenian
436
25
Helo, given ##f:R^n\rightarrow R^m## and ##g:R^m\rightarrow R^e## both class ##C^m##. Is the composition ##g\circ f## of class ##C^m## ?.
Yes, use the chain rule to prove it.
Likes facenian and member 587159
BTW, I believe this exercise appears in Munkres Analysis on Manifolds with a suitable guidance, but I am not 100% sure.
FAQ: Elementary question on composition of functions
What is the definition of composition of functions?
Composition of functions is an operation that combines two or more functions to create a new function. It is denoted by (f · g)(x) and is read as "f of g of x". This means that the output of g(x) is used as the input for f(x).
How do you evaluate a composition of functions?
To evaluate a composition of functions, you first need to identify the inner and outer functions. Then, substitute the input value into the inner function and use the resulting output as the input for the outer function. Finally, simplify the expression to get the final value.
What is the difference between the composition of functions and the product of functions?
The composition of functions is an operation that combines two functions to create a new function. The product of functions, on the other hand, is an operation that multiplies two functions together to create a new function. In composition, the output of one function is used as the input for the other function, while in product, the functions are multiplied together using the same input value.
Can any two functions be composed?
No, not all functions can be composed. In order for two functions to be composed, the output of the inner function must be in the domain of the outer function. This means that the input value for the inner function must also be a valid input for the outer function.
What is the associative property of composition of functions?
The associative property of composition of functions states that the order in which functions are composed does not matter. In other words, (f · g) · h = f · (g · h). This means that you can group functions in any way you want when composing them, and the result will be the same.
