Steven925
- 1
The prompt for the question I am seeking help on is:
"A freezer contains 20 kg of food with a specifit heat of 2x10^3 J/kg*c. The temperature inside the freezer is initially -5*C. The freezer motor them operates for 10 minutes, reducing the temperature to -8*C."
I have found solutions to the first three portions of the question:
a)How much heat is removed from the food during this time? The freezer operates at 400W
Q = -120,000J using Q = CM(t(f) - t(i))
b)How much energy is delivered to the freezer motor suring the 10 minute period?
P = W/T = 240,000J
c)During this time, how much total heat is ejected into the room in which the freezer is located?
Q = Q + W = 360,000J
D is what i need help on:
"Determine the temperature change in the room if the specific heat of air is 700J/Kg*C. assume there are 80 kilograms of air in the room, the volume of the air is constant, and there is no heat loss from the room"
I have tried using the standard Q = cm(delta)t:
360,000J = 700J/Kg*c * 80 (delta)t
but that comes out to approximately 6.2 degrees celcius. My instructor says the answer is 7.3*C and I'm unsure of what I may be doing incorrectly. Any guidance would be greatly appreceiated.
Thanks!
P = W/T = 240,000J
Thanks!
