Elements of an Equivalence Class
In summary, the equivalence relation on the set of integers defined by a~b if a-b is divisible by 5 can be used to prove that the product of two elements in the equivalence classes of m and n also belongs to the equivalence class of mn. This can be shown by substituting m and n with the corresponding elements in the equation mn-kl=5z, and simplifying to show that it is a multiple of 5.
Numberphile
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >
Question:
Let ~ be the equivalence relation on the set ℤ of integers defined by a~b if a-b is divisible by 5. Let k ∈ Em belong to the equivalence class of m, and l ∈ En belong to the equivalence class of n. Prove that the product kl belongs to the equivalence class Emn.
What I've tried:
Since k ∈ Em, then m - k = 5x, for x ∈ ℤ.
Also, since l ∈ En, then n - l = 5y, for y ∈ ℤ.
So, I need to show that m*n - k*l = 5z, for z ∈ ℤ.
I've tried multiplying (m-k)*(n-l), but to no avail.
So I tried one case. Let m=20, k=10, n=30, and l=5.
Well, 20-10=5(2), so 10 ∈ E20, and 30-5=5(5), so 5 ∈ E30
Also, 600-50=5(110), so 50 ∈ E600, which for this case means kl ∈ Emn.
Dilemma:
I'm convinced the product kl belongs to the equivalence class of m*n always, so I'm having trouble actually finding a systematic way of proving it in general, instead of using a specific case.
Numberphile said:
Question:
What I've tried:
So, I need to show that m*k - n*l = 5z, for z ∈ ℤ.
Dilemma:
Why haven't you calculated what you are actually looking for: ##m\cdot n - k \cdot l##?
I haven't calculated that because I'm not sure what that would represent.
I know an equivalence class is defined as a relation on a set S with x ∈ S, then the equivalence class of x is
Ex = {y ∈ S | x ~ y}
Here's the answer:
And here's the way:
##mk-kl = (5x+k)(5y+l)-kl= \dots ##
I may have made a mistake in my "What I've tried" section.
I already corrected it in my original post.
It should have read
My apologies.
It should have readMy apologies.
No, my sorry, I had a typo. Of course it's ##mn-kl=(5x-k)(5y-l)-kl= \dots##
The point is: you already have everything you need in your post. What is ##mn-kl##?
I'm not sure that I follow the logic.
mn - kl = (5x+k)(5y+l) - kl
I expanded this, and trivially, I obtain that mn - kl = mn - kl
You set ##m=5x-k## and ##n=5y-l## which you can do because ##k\in E_m## and ##l\in E_n##.
This is correct. Also correct is, that ##mn-kl=5z## for some ##z \in \mathbb{Z}## has to be shown, because it would mean ##E_{mn}=E_{kl}## what we need. Now, simply substitute ##m## and ##n## to get
##mn-kl=(5x-k)(5y-l)-kl=25xy-5xl-5yk+kl-kl=25xy-5xl-5yk=5z##.
This line was all what's been missing.
Ah, I see it now! (Though I think the signs are a bit off, but nonetheless it should be the same)
Since 25xy + 5xl + 5yk = 5(5xy) + 5(xl) + 5(yk) = 5[5xy + xl +yk], then this is just an 5z, as [5xy + xl + yk] is just some integer.
Perfect! Thank you so much.
Likes fresh_42
Related to Elements of an Equivalence Class
What is an equivalence class?
An equivalence class is a set of objects or elements that are considered to be equivalent based on a specific criteria or relationship.
What are the elements of an equivalence class?
The elements of an equivalence class are the objects or elements that belong to the same class and are considered to be equivalent.
How are equivalence classes identified?
Equivalence classes are identified by a specific equivalence relation, which is a rule or criteria used to determine whether two objects or elements belong to the same class.
What is the purpose of studying equivalence classes?
Studying equivalence classes can help us better understand the relationships and patterns between objects or elements, and can also be used to classify and organize data.
What are some examples of equivalence classes?
Examples of equivalence classes include even and odd numbers, positive and negative numbers, and shapes with the same number of sides.
  • Astronomy and Astrophysics
