Elevator pulled upward by cable - find tension
In summary, the question is about finding the tension in a cable that is pulling an elevator cab upward, with a combined mass of 2000kg, and its single occupant dropping a coin with an acceleration of 8.00m/s^2 downward. The conversation discusses how this relates to the acceleration of the cab and how the tension in the cable balances the weight of the cab. The final calculation shows the tension to be 16000 N.
shawpeez
here's the question,
An elevator cab is pulled upward by a cable. The cab and its single occupant have a combined mass of 2000kg. When that occupant drops a coin, its acceleration relative to the cab is 8.00m/s^2 downward. What is the tension in the cable?
could someone explane to me how to relate the accerleration of the coin downward to the acceleration of the cab being pulled up.
IF the elevator is going up, and the apparent acceleration in the cab is less than 9.8 m/s/s, then the elevator is at that moment slowing down.
If an object is being pulled up at a constant velocity, then there is zero acceleration because forces are balanced (specifically, the tension in the cable balances the weight). Dropping the coin inside at this moment, the coin would display normal acceleration to the person inside the cab, no matter what speed the elevator was doing.
If the elevator is slowing down, then the upward tension in the cable must be slightly less than the total weight (thereby making net force NOT zero but slightly downward).
So what's the accelration of the cab, if gravitational acceleration "seems to be" 1.8 m/s/s less than normal?
My first instinct was that the upward acceleration of the cab was slowing down, this is what i did
Fnet= T - mg = ma
T - 2000(9.8) = 2000(-1.8)
T - 19600 = -3600
T= 19600 - 3600
T = 16000 N
Is this correct ?
You are correct. Follow that instinct (but don't say "the acceleration was slowing down," it's the speed that is slowing down.)
thanks for the help:smile:
FAQ: Elevator pulled upward by cable - find tension
How does an elevator stay up when pulled upward by a cable?
When an elevator is pulled upward by a cable, the tension in the cable increases. This tension is transmitted to the elevator car through the supporting pulleys, which helps to counteract the force of gravity and keep the elevator in a stable position.
How is the tension in the cable calculated?
The tension in the cable is calculated using Newton's Second Law of Motion, which states that force equals mass times acceleration (F=ma). The force in this case is the weight of the elevator and its occupants, and the acceleration is the upward acceleration of the elevator.
What factors can affect the tension in the cable?
The tension in the cable can be affected by the weight of the elevator and its occupants, the distance the elevator needs to travel, and the speed at which it travels. Changes in these factors can cause the tension to increase or decrease accordingly.
How does the tension in the cable change as the elevator moves?
As the elevator moves, the tension in the cable changes. When the elevator is at rest, the tension is equal to the weight of the elevator and its occupants. As the elevator starts to move, the tension increases to counteract the force of gravity. The tension continues to increase as the elevator gains speed, and then decreases as the elevator slows down and comes to a stop.
Why is it important to have the correct tension in the elevator cable?
The correct tension in the elevator cable is crucial for the safety and efficiency of the elevator. If the tension is too low, the elevator may not be able to support its weight and could potentially fall. On the other hand, if the tension is too high, it could put unnecessary strain on the elevator's components and lead to mechanical issues. Therefore, it is important to calculate and maintain the correct tension in the cable to ensure safe and smooth operation of the elevator.
