Ellipse chord subtending a right angle
In summary, to show that the equation of the chord on an ellipse joining points P and Q is bx cos\frac{1}{2}(\theta+\phi)+ay\sin\frac{1}{2}(\theta+\phi)=ab\cos\frac{1}{2}(\theta-\phi), we need to use a parametric approach and manipulate the expression \frac{\cos(\frac{\theta-\phi}{2})}{\cos(\frac{\theta+\phi}{2})}. By substituting theta=2A and phi=2B, we can show that the point of intersection of the chord with the x-axis is a(\frac{a^2+b^2}{a^2-b^2},
Appleton
91
Show that the equation of the chord joining the points [itex]P(a\cos(\phi), b\sin(\phi)) [/itex]and [itex]Q(a\cos(\theta), b\sin(\theta))[/itex] on the ellipse [itex]b^2x^2+a^2y^2=a^2b^2 [/itex] is [itex] bx cos\frac{1}{2}(\theta+\phi)+ay\sin\frac{1}{2}(\theta+\phi)=ab\cos\frac{1}{2}(\theta-\phi)[/itex].
Prove that , if the chord PQ subtends a right angle at the point (a,0), then PQ passes through a fixed point on the x axis.
The second part of the question is where I am having difficulty.
The question seems to suggest a parametric as opposed to cartesian approach.
PQ subtends a right angle ⇒
[itex]
(\frac{b^2}{a^2})(\frac{\sin(\phi)}{1-\cos(\phi)})(\frac{\sin(\theta)}{1-\cos(\theta)})=-1
[/itex]
The coordinates of the intersection of PQ with the x-axis are
[itex]
(a\frac{\cos(\frac{\theta-\phi}{2})}{\cos(\frac{\theta+\phi}{2})}, 0)
[/itex]
Presumably I should be able to manipulate the first expression to yield a constant value for [itex]
[/itex] however, I don't seem to be making much progress in this respect.
Since one of the expressions involves half angles, try substituting theta=2A, phi=2B everywhere.
That seems to have done the trick. So the point of intersection is the constant value
[itex]
a(\frac{a^2+b^2}{a^2-b^2},0)
[/itex]
Thanks for your help.
[itex]
[/itex]
Well done.
Related to Ellipse chord subtending a right angle
1. What is an ellipse?
An ellipse is a closed curve that is formed by the intersection of a cone and a plane. It is a type of conic section, and its shape resembles that of a flattened circle.
2. What does it mean for a chord to subtend a right angle in an ellipse?
Subtending a right angle means that the chord, which is a straight line connecting two points on the ellipse, forms a 90 degree angle with the tangent line at one of those points.
3. How is the length of an ellipse chord subtending a right angle calculated?
The length of the chord can be calculated using the formula c = a√2(1 - e²), where c is the length of the chord, a is the semi-major axis of the ellipse, and e is the eccentricity of the ellipse.
4. What is the significance of an ellipse chord subtending a right angle in mathematics?
The concept of an ellipse chord subtending a right angle is important in geometry and trigonometry, as it helps to determine the relationship between the sides and angles of an ellipse. It is also used in the study of conic sections and their properties.
5. Can an ellipse chord subtending a right angle have a length of 0?
No, an ellipse chord subtending a right angle cannot have a length of 0. This is because the length of the chord is dependent on the semi-major axis and eccentricity of the ellipse, and both of these values must be greater than 0 for an ellipse to exist.
  • Topology and Analysis
