Elliptic Cylinder: What Determines Radius & Height?
  • MHB
  • Thread starter Yankel
  • Tags
    Cylinder
In summary, the conversation discussed the formula for an elliptic cylinder and its components. The main question was about the representation of the radius and height in the formula and how it differs for different cylinders. It was clarified that the ellipse does not have a radius, but major and minor axes, and the center of the cylinder is at the origin. The height of the cylinder can be denoted by placing a restriction on the z-axis.
Yankel
395
Hello all,
I have a theoretical question. This is the formula for an elliptic cylinder (right?)
\[\frac{x^{2}}{a^{2}}+\frac{y^{2}}{b^{2}}=1\]
I understand that the point (a,b) represent the center of the basic ellipse of the cylinder. What in the formula represent the radius of the basic ellipse ? What determines the height of the cylinder ?
In other words, if I have two cylinders, let's say both with a base centered at (1,1), but one has a radius of 2 and height 1, and the other radius 5 with height 4, how will the equations differ ?
Many thanks !
Mathematics news on Phys.org
The ellipse does not have a radius, but rather major and minor axes. The center of the cross-sections of the cylinder you cite is at the origin, not $(a,b)$. An ellipse in two dimensions centered at $(h,k)$ is given by:
\(\displaystyle \frac{(x-h)^2}{a^2}+\frac{(y-k)^2}{b^2}=1\)
To denote the height of the cylinder, you could place a restriction on $z$, such as $0\le z\le h$.
FAQ: Elliptic Cylinder: What Determines Radius & Height?
What is an elliptic cylinder?
An elliptic cylinder is a three-dimensional shape that is created by extending an ellipse along its major axis. It is similar to a cylinder, but its cross-sections are ellipses instead of circles.
How is the radius of an elliptic cylinder determined?
The radius of an elliptic cylinder is determined by the length of its major axis, which is the longest diameter of the ellipse. This can be measured using a ruler or calculated using the equation for the circumference of an ellipse.
What factors determine the height of an elliptic cylinder?
The height of an elliptic cylinder is determined by the length of its minor axis, which is the shortest diameter of the ellipse. Additionally, the height can be altered by changing the angle at which the ellipse is extended along the major axis.
Can an elliptic cylinder have different radii and heights?
Yes, an elliptic cylinder can have varying radii and heights. The radii can be different for each cross-section along the major axis, and the height can be adjusted by changing the angle of extension.
How is an elliptic cylinder used in real-world applications?
An elliptic cylinder is commonly used in architecture and engineering for creating curved structures. It is also used in manufacturing processes for creating curved products, such as pipes or tubes. Additionally, it has applications in mathematics and physics for studying the properties of three-dimensional shapes.
