Elliptic geometry in 3 dimensions
In summary, elliptic geometry in 3 dimensions is a non-Euclidean geometry based on the geometry of a sphere where the sum of angles in a triangle is greater than 180 degrees and parallel lines intersect at the poles of the sphere. It differs from Euclidean geometry in that the sum of angles in a triangle is always 180 degrees and parallel lines never meet. Some real-life applications include navigation, map-making, and astronomy, and key concepts include great circles, antipodal points, and geodesics. Elliptic geometry is related to other non-Euclidean geometries such as hyperbolic geometry and Riemannian geometry, all of which differ from Euclidean geometry in terms of their axioms and properties.
TrickyDicky
3,507
27
I'm interested in elliptic space from an intrinsic point of view(manifold pov) rather than the models based in Euclidean embeddings.
Would it be correct to say that the isometry group of this geometry is isomorphic to SU(2), i.e.:versors or unit quaternions?
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Related to Elliptic geometry in 3 dimensions
What is elliptic geometry in 3 dimensions?
Elliptic geometry in 3 dimensions is a non-Euclidean geometry where the sum of the angles of a triangle is greater than 180 degrees. It is based on the geometry of a sphere, where lines are represented as great circles and parallel lines do not exist.
How is elliptic geometry different from Euclidean geometry?
In Euclidean geometry, the sum of the angles of a triangle is always 180 degrees and parallel lines never meet. In elliptic geometry, the sum of the angles of a triangle is greater than 180 degrees and parallel lines intersect at the poles of the sphere.
What are some real-life applications of elliptic geometry in 3 dimensions?
Elliptic geometry in 3 dimensions has applications in navigation, map-making, and astronomy. It is also used in the study of spherical objects, such as planets and stars.
What are some key concepts in elliptic geometry in 3 dimensions?
Some key concepts in elliptic geometry in 3 dimensions include great circles, antipodal points, and geodesics. Great circles are the equivalent of straight lines in Euclidean geometry, antipodal points are points on a sphere that are directly opposite each other, and geodesics are the shortest paths between two points on a sphere.
How is elliptic geometry related to other non-Euclidean geometries?
Elliptic geometry is one of three non-Euclidean geometries, along with hyperbolic geometry and Riemannian geometry. These geometries differ from Euclidean geometry in terms of their axioms and the properties of their shapes and spaces. Elliptic geometry and hyperbolic geometry are both curved geometries, while Riemannian geometry is a flat geometry.
