I How Do Time-Varying Currents in Conductors Generate EM Fields and Waves?
A conductor carrying a time-varying electric current generates an electromagnetic field, which can either remain in the near field or radiate as electromagnetic waves into the far field. The near field is associated with localized electromagnetic induction, while the far field results from the cumulative effects of all circuit elements radiating energy. In larger circuits with small wavelengths, the phase of currents can vary, complicating the summation of fields. Both local and radiated fields exist in circuits with varying currents, with energy being stored locally and lost as radiated waves. The key condition for producing electromagnetic fields in both regions is the acceleration or deceleration of charged particles.
crocodile_
Hello, I'm new to this forum. I have a short question that I can't solve on my own, I've consulted many books but I can't find solutions, I hope you can help me.
Then considering a conductor traversed by an electric current that varies over time, it produces an electromagnetic field, under certain conditions the electromagnetic field moves further and further away from the conductor and electromagnetic waves are created.
Here are the conditions under which a conductor produces only an electromagnetic field in the near field such as EM induction or transcranial magnetic stimulation, and under which other conditions does it instead produce electromagnetic waves (far field)?
Welcome to PF.
You have considered only a short piece of wire and the near field it radiates. That piece of wire is just one element of a closed circuit with current flowing.
The far field is the sum of all the fields radiated by the current in all the elements of that circuit. For big circuits and small wavelengths, the phase of the currents may vary about the circuit, which makes the summation more interesting.
The magnetic fields radiated by the circuit are accompanied in space by a perpendicular electric field.
Electric circuits with varying current, unless of shielded construction, will have both local fields, in which energy is stored, and radiated fields, where energy is lost from the circuit due to the creation of radiated EM waves. The radiated energy is small when the dimensions of the circuit are small compared to the wavelength.
Whenever a charged particle is accelerated or decelerated electromagnetic radiation will be produced. The only condition for generating an electromagnetic field in the near-field region and in the far-field region is a charged particle with changing its velocity.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
