EM field lines in non-isotropic media
In summary, in non-isotropic media, the orientation of electromagnetic field lines can vary and affect the propagation of electromagnetic waves. In TDR measurements of soil moisture, the presence of moisture and air gaps can change the permittivity and affect the speed of the wave. The direction of the electric field in non-isotropic media may be biased in the case of ferromagnetic materials, but this is not always the case. The speed of the electromagnetic wave in materials is affected by the permittivity and permeability of the material, and the electrons in TDR rods do not have to physically move for the wave to propagate. For more specific calculations and derivations, it is recommended to consult with the author or a specialist in the field
Bak
Electromagnetic field lines in non-isotropic media
Hello,
We are using time domain reflectometry (TDR) in soils to measure soil moisture.
I want to know how the electromagnetic fields are oriented when the soil is not isotropic, i.e some parts of the soil consist of moist or wetter parts, other parts in the soil matrix consist of dry air gaps.
TDR: 2 metal rods of 10cm are placed parallel in soil material at a distance of about 3 cm. An electrical step pulse is applied to the rods. The EM wave travels along the rods with a velocity that is dependent on the constitution of surrounding material. At the end of the rods the wave is reflected by an impedance change and travels back. The total traveltime of the wave is then measured and is a measure of the permittivity and thereby of the moisture content of the soil. But not all soils happen to be isotropic. So what happens in non-isotropic soils?
If I understand the article of Annan, A.P. 1977, Time-Domain Reflectometry - Air gap problem for parallel wire transmission lines well, he assumes that the direction of the electric field is not biased by the medium (at least it is not mentioned in the paper).
  1. I do not know how he comes to the entire solution, because only the last part of the derivation is mentioned in the paper. Can anybody help? I would like to know the entire derivation to be able to calculate other situations. Electro magnetic fields are not my daily routine.
  2. I know that EM field directions can be biased by a ferro-like material like in a transformer. Is in that case the bias caused by EM induction in the metal by which one side of it becomes more positive charged than the other and thus changes the direction of the EM field?
  3. Can it than be possible that moist soil does the same job, whereas de EM field lines concentration is larger at moist soil positions compared to the concentration in dry air gaps?
  4. And doesn't that change the net effect of air gaps in the travel time of the electromagnetic field in the rods of the TDR?
  5. Furthermore I am struggeling with the fact that electrons move relatively slow in the rods when a voltage is applied. When placed in vacuum however the EM wave travels with the speed of light. How can that be possible since it travels along the rods and is induced by the potential change. Can I assume that the electrons don't move at all, only at the biginning of the step at the beginning of the rods?
  6. Am I correct when I say: extra electrons are pumped into the rods but cannot move; the step causes an EM wave to occur. This wave travels along rods (why in this direction? When the electrons cannot move I assume that at the beginning of the rods there is an overkill of electrons causing it to be a point charge?), reach the end of the rods, meet a different permittivity (not the soil, but the end of the rods) and thus reflect back to the beginning of the rods.
  7. If electrons do move though, how are they related to the speed of the EM wave?
Thank you.
Thank you for your interesting question about electromagnetic field lines in non-isotropic media. As a scientist with expertise in electromagnetics, I am happy to provide some insights on this topic.
Firstly, in non-isotropic media, the orientation of electromagnetic field lines can vary depending on the composition and structure of the material. This can affect the propagation of electromagnetic waves and the results obtained from TDR measurements. In the case of soil, the presence of moisture or air gaps can change the permittivity of the material, which in turn affects the speed of the electromagnetic wave.
In the paper by Annan, A.P. 1977, the author assumes that the direction of the electric field is not biased by the medium. This is a valid assumption in many cases, but it may not hold true for all non-isotropic media. In materials with ferromagnetic properties, such as transformers, the electromagnetic field lines can be biased due to induced currents in the material. In the case of moist soil, it is possible that the concentration of the electric field lines may be higher in areas with higher moisture content, but this would depend on the specific properties of the soil.
The presence of air gaps can also affect the travel time of the electromagnetic wave in TDR measurements. In general, the wave will travel faster in areas with higher permittivity, such as moist soil, and slower in areas with lower permittivity, such as air gaps. This can lead to changes in the overall travel time and can affect the accuracy of the results obtained.
Regarding your question about the speed of the electromagnetic wave, it is important to note that the speed of light is the speed at which the electromagnetic wave propagates in a vacuum. In materials, the speed of the wave is affected by the permittivity and permeability of the material. In the case of TDR measurements, the electrons in the rods do not have to physically move for the wave to propagate. The step pulse applied to the rods induces an electromagnetic wave that travels along the rods, and the electrons simply respond to this wave.
I hope this helps to clarify some of your questions and concerns. If you would like to learn more about the specific calculations and derivations mentioned in the paper by Annan, A.P. 1977, I suggest reaching out to the author directly or consulting with a specialist in the field of electromagnetics. Thank you for your interest in this topic and happy researching
Related to EM field lines in non-isotropic media
1. What are EM field lines in non-isotropic media?
EM field lines in non-isotropic media refer to the path that an electromagnetic field takes in a material that is not uniform in all directions. This means that the properties of the material, such as its conductivity or permittivity, vary in different directions, resulting in a non-uniform distribution of the electromagnetic field.
2. How do EM field lines behave in non-isotropic media?
In non-isotropic media, EM field lines are affected by the varying properties of the material. This can cause the field lines to bend, distort, or even break in some cases. The direction and strength of the field lines are also influenced by the non-uniformity of the material.
3. What factors affect EM field lines in non-isotropic media?
The properties of the material, such as its conductivity, permeability, and dielectric constant, are the main factors that affect EM field lines in non-isotropic media. Other factors such as the geometry and orientation of the material, as well as the frequency and strength of the electromagnetic field, can also have an impact.
4. How are EM field lines in non-isotropic media different from those in isotropic media?
In isotropic media, the properties of the material are uniform in all directions, resulting in symmetric and straight EM field lines. However, in non-isotropic media, the varying properties of the material cause the field lines to be asymmetric and curved or distorted.
5. What are the applications of understanding EM field lines in non-isotropic media?
Understanding EM field lines in non-isotropic media is crucial in many fields, such as material science, engineering, and physics. It allows for better design and optimization of materials and devices that use electromagnetic fields, such as antennas, sensors, and medical imaging equipment.
  • Electromagnetism
  • Atomic and Condensed Matter
  • Other Physics Topics
  • Electromagnetism
  • Quantum Physics
