roeb
- 107
- 1
A particle of mass m and charge q is attached to a spring with force constant k, hanging from the ceiling. Its equilibrium position is a distance h above the floor. It is pulled down a distance d below equilibrium and released, at time t = 0;
Under the usual assumptions (d << lambda << h) calculate the intensity of the radiation hitting the floor as a function of the distance R from the point directly below q.
I see that this is a harmonic oscillator that could be described by x(t) = d cos(wt)
and a = -w*w*dcos(wt)
I would like to use Larmor's formula: P = u_0 q^2 a^2 / ( 6 pi m c) but I believe that I may need to revert back the to Poynting vector because we are only trying to find intensity [W/area] so: S = u_0 q^2 a^2 / ( 32 pi m c).
I think I'm having a hard time determining how to draw the picture to visualize this situation. How do I handle finding the intensity on the floor? I see that the distance from the mass to the floor is (R^2 + (h+delta)^2)^1/2.
Does anyone have any tips on how to get started with this? Do I need to rewrite the electric and magnetic fields and recalculate the Poynting vector from scratch (re-derive the electric dipole equations essentially?)
