EM vector potential - covariant or contravariant?
In summary, the Maxwell equations involve potential components that are either covariant or contravariant, depending on the chosen signature for the metric. The sign convention also affects the Lorentz force law and the 4-velocity, but does not change the invariance of the fields derived. However, the choice of metric does impact the value of the invariant A^{\mu}A_{\mu} and can change the signs of the magnetic potential coefficients when considering a subspace of three dimensions.
pellman
684
Are potentials appearing in the Maxwell equations the components of a contravariant vector or a covariant vector?
Let us be specific. metric is (+,-,-,-) . Let us write the potentials which appear in the Maxwell equations as [tex]\Phi[/tex] and [tex]\vec{A}=(A_x,A_y,A_z)[/tex]
Is it then the case that
[tex]A^{\mu}=(\Phi,A_x,A_y,A_z)[/tex]
[tex]A_{\nu}=(\Phi,-A_x,-A_y,-A_z)[/tex]
or
[tex]A^{\mu}=(\Phi,-A_x,-A_y,-A_z)[/tex]
[tex]A_{\nu}=(\Phi,A_x,A_y,A_z)[/tex]
Yes, but the OP is asking about sign conventions.
A is naturally a 1-form, and the sign is chosen such that F = dA. In index notation, this is
[tex]F_{\mu\nu} = \partial_\mu A_\nu - \partial_\nu A_\mu[/tex]
Furthermore, the sign of F is chosen such that the Lorentz force law reads
[tex]\dot u_\mu = \frac{q}{m} F_{\mu\nu} u^{\nu}[/tex]
and the 4-velocity u is naturally a (contravariant) 4-vector.
or
[tex]A^{\mu}=(\Phi,-A A^\mu_x,-A_y,-A_z)[/tex]
The [tex]A^\mu[/tex] has all positive signs. Then the divergence of A is [tex]\partial_\mu A^\mu[/tex].
What effect does switching the signature have, from the perspective of calculation?
Would it switch covariant with contravariant?
The fields derived should be invariant surely, since it's just two ways of representing the same physical thing?
Changing the metric does not change that
[tex]A^\mu=[\phi,{\vec A}][/tex].
It would make [tex]A^\mu A_\mu={\vec A}^2-\phi^2[/tex]
and [tex]p^\mu p_\mu=-m^2[/tex], which is why I don't like the
=-1,1,1,1 metric.
No, it only changes the sign of the invariant [tex]A^{\mu}A_{\mu}[/tex]
=-1,1,1,1 metric.
Amen! [tex]p^\mu p_\mu=-m^2[/tex] is obscene.
Thanks!
One thing of which you should be aware. The magnetic potential coefficients taken alone are equally covariant or contravariant. The subspace is three dimensions of space, and the space3 metric is (+++), so we can raise and lower indices without concern; the signs are unaltered. Ai=Ai. When this subspace metric becomes an entry in the two-by-two metric of space and time, we choose to assign coefficients of either -1 and 1 or 1 and -1 respective to choice.
FAQ: EM vector potential - covariant or contravariant?
1. What is the difference between covariant and contravariant EM vector potential?
The EM vector potential is a mathematical concept used in electromagnetic theory to describe the magnetic and electric fields that exist in a given space. The terms "covariant" and "contravariant" refer to how the vector potential transforms under a change of coordinates.
In simple terms, a covariant vector potential changes its components when the coordinates are changed, while a contravariant vector potential does not change its components. This is similar to the difference between a row vector and a column vector in linear algebra.
2. How do covariant and contravariant vector potentials relate to each other?
Covariant and contravariant vector potentials are related by the metric tensor, which is a mathematical object that describes how coordinates are related to each other in a given space. The metric tensor is used to transform between covariant and contravariant vectors.
In electromagnetism, the vector potential is often written in terms of its covariant components, but it can also be expressed in terms of its contravariant components. The relationship between the two is given by the metric tensor.
3. Why are covariant and contravariant vector potentials important in electromagnetism?
Covariant and contravariant vector potentials are important in electromagnetism because they allow us to describe the same physical phenomenon in different coordinate systems. In electromagnetism, the equations that govern the behavior of electric and magnetic fields are written in terms of the vector potential, so it is crucial to have a way to transform between different coordinate systems.
Covariant and contravariant vector potentials also have practical applications, such as in the design of antennas and other electromagnetic devices, where it is important to understand how the fields behave in different coordinate systems.
4. How are covariant and contravariant vector potentials used in relativistic physics?
In relativistic physics, covariant and contravariant vector potentials are used to describe the behavior of electromagnetic fields in a four-dimensional spacetime. In this context, the vector potential is combined with other mathematical objects, such as the electromagnetic field tensor, to form the electromagnetic four-potential.
The use of covariant and contravariant vector potentials allows for the formulation of Maxwell's equations in a covariant form, which is essential for understanding electromagnetic phenomena in the context of special relativity.
5. Are covariant and contravariant vector potentials used in any other fields of science?
Yes, covariant and contravariant vector potentials have applications in many other fields of science, such as general relativity, fluid mechanics, and quantum mechanics. In these fields, the vector potential is often used to describe the behavior of fields and particles in different coordinate systems.
In general relativity, covariant and contravariant vector potentials are used to describe the behavior of gravitational fields, while in fluid mechanics, they are used to describe the flow of fluids in different coordinate systems. In quantum mechanics, the vector potential is used to describe the behavior of particles in the presence of electromagnetic fields.
