EM Wave: Phase of the electric and magnetic waves?
In summary, the plane wave solutions to Maxwell's Equations, given by E=E0*cos(wt-kr) and B=B0*cos(wt-kr), are in phase. This may seem counterintuitive, as one would expect the magnetic field to be 90 degrees out of phase with the electric field. However, upon substitution into Maxwell's equations, it can be seen that these solutions satisfy the equations and the curl of the magnetic field is related to the rate of change of the electric field, rather than the magnitude of the electric field itself.
PeterPeter
23
In a vacuum, the plane wave solutions to Maxwell's Equations are...
E=E0*cos(wt-kr)
B=B0*cos(wt-kr)
ie they are in phase. (See for example
https://www.physics.wisc.edu/undergrads/courses/spring08/208/Lectures/lect20.pdf
http://hyperphysics.phy-astr.gsu.edu/hbase/waves/emwv.html )
I don't understand how they can be in phase. I expected them to be 90 degrees out of phase because a changing electric field causes a magnetic field. So when the electric field is changing the most the magnetic field should be greatest. Since the differential of cos is sin, I'd expected the magnetic field to be 90 degrees out of phase. Where am I going wrong?
Have you tried substituting them into Maxwell's equations to verify that they are indeed a solution? Make sure to use a suitable vector form for the solution. For a plane wave propagating in the z-direction, one such form is $$\vec E = \hat x E_0 \cos (\omega t - kz) \\ \vec B = \hat y B_0 \cos (\omega t - kz)$$ More explicitly in terms of components: $$E_x = E_0 \cos (\omega t - kz) \\ E_y = 0 \\ E_z = 0 \\ B_x = 0 \\ B_y = B_0 \cos (\omega t - kz) \\ B_z = 0$$ Consider for example the equation $$\nabla \times \vec E = - \frac {\partial \vec B}{\partial t}$$ On the left side you have first derivatives with respect to x, y, z, of components of ##\vec E##, which give you (for my example) either zeroes or sines. On the right side you have the first derivatives with respect to t, of components of ##\vec B##, which again give you either zeroes or sines.
Maxwells equations does not say that. It says that when the electric field is changing the most the curl of the Magnetic field should be the greatest.
Related to EM Wave: Phase of the electric and magnetic waves?
1. What is the relationship between the electric and magnetic waves in an EM wave?
The electric and magnetic waves in an EM wave are perpendicular to each other and oscillate in sync, creating a self-sustaining electromagnetic field.
2. How does the phase of the electric and magnetic waves affect the properties of an EM wave?
The phase of the electric and magnetic waves determines the direction and strength of the electromagnetic field, which in turn affects the intensity and polarization of the EM wave.
3. Can the phase of an EM wave be manipulated or controlled?
Yes, the phase of an EM wave can be manipulated by changing the relative timing of the electric and magnetic waves. This can be done using devices such as phase shifters or by changing the distance between the source and receiver of the EM wave.
4. How is the phase of an EM wave measured?
The phase of an EM wave is typically measured using an oscilloscope, which displays the oscillating electric and magnetic fields over time. The phase can also be measured using interferometry techniques.
5. What are the different phases of an EM wave and how do they differ?
The different phases of an EM wave refer to the relative timing of the electric and magnetic waves. In-phase waves have their peaks and valleys aligned, while out-of-phase waves have their peaks and valleys offset. This affects the properties of the EM wave, such as its polarization and direction of propagation.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
