EM wave/radiation from which equations?
  • Thread starter Thread starter xxxyyy
    Em
The discussion centers on the relationship between electromagnetic (EM) radiation and the equations governing it, particularly referencing Feynman's lectures and the Heaviside-Feynman formula. It clarifies that wave solutions for scalar and vector potentials indeed translate into wave solutions for the electric and magnetic fields, as derived from Maxwell's equations. The conversation questions whether the wave phenomena originate solely from the acceleration term in Feynman's formula or also from the homogeneous solutions of the wave equations. There is confusion regarding the completeness of Feynman's explanation, particularly why he does not include homogeneous solutions in his discussion of classical EM theory. The participants seek clarity on the implications of these equations for understanding wave behavior in EM fields.
xxxyyy
Hi there,
in Feynmann's lectures, (Vol 2 eq (21.1) Heaviside-Feynman forumla)
https://www.feynmanlectures.caltech.edu/II_21.html
it is said that radiation comes from the last term, the one with acceleration in it. This formula is a particular case of the Jefimenko equations, the ones derived from Lienard-Wiechert potentials.
These potentials are particular solutions of the inhomogeneus wave equations for the potentials (in Lorenz gauge). I should add the general solution of the homogeneus equestions, i.e. wave solutions, to get the true general solution.
Does wave solutions for the potentials translate into wave solutions for the fields?
And where does exactly the wave phenomenon come from? from the homogeneus solution or from the second time derivative Feynman was talking about in his (21.1) formula?
Thank you!
Absolutely yes. If you have solutions ##V,\vec{A}## for the scalar potential and vector potential that satisfies the homogeneous or inhomogeneous wave equation, then the fields defined by $$\vec{E}=-\nabla V-\frac{\partial \vec{A}}{\partial t}$$ and $$\vec{B}=\nabla\times\vec{A}$$ satisfy the wave equation as well. To prove it is a not so hard vector calculus excercise, you will utilize Maxwell's equation (in differential form) and some vector calculus identities and the Lorentz gauge condition.
Set ##\phi = 0## such that ##\mathbf{E} = - \dfrac{\partial \mathbf{A}}{\partial t}## and ##\mathbf{B} = \nabla \times \mathbf{A}##. Set also ##\nabla \cdot \mathbf{A} = 0## then from Maxwell\begin{align*}
\Delta \mathbf{A} - \frac{\partial^2 \mathbf{A}}{\partial t^2} &= 0 \ \ \ (1) \\
\end{align*}Take the curl of ##(1)##,\begin{align*}
\Delta ( \nabla \times \mathbf{A} )- \frac{\partial^2}{\partial t^2}\left( \nabla \times \mathbf{A} \right) &= 0 \\
\Delta \mathbf{B} - \frac{\partial^2 \mathbf{B}}{\partial t^2} &= 0
\end{align*}Instead take the time derivative of ##(1)##,\begin{align*}
\Delta \left( \frac{\partial \mathbf{A}}{\partial t}\right) - \frac{\partial^2}{\partial t^2} \left( \frac{\partial \mathbf{A}}{\partial t} \right) &= 0\\
\Delta \mathbf{E} - \frac{\partial^2 \mathbf{E}}{\partial t^2} &= 0
\end{align*}The wave equations holds on ##\mathbf{E}## and ##\mathbf{B}##. Let ##\xi## be any component of either of these vectors, i.e. ##\Delta \xi - \dfrac{\partial^2 \xi}{\partial t^2} = 0## and let ##\xi(\boldsymbol{x},t) = f(p)## where ##p = k_1 x + k_2 y + k_3 z + k_4 t##. Then ##\dfrac{\partial^2 \xi}{\partial x_i^2} = k_i^2 \dfrac{d^2 f}{dp^2}## hence ##k_1^2 + k_2^2 + k_3^2 - k_4^2 = 0##. You may simply let ##k_4 = \pm 1## so that ##\hat{\mathbf{k}} = (k_1, k_2, k_3)## form the components of a unit vector. Then ##p_{\pm} = \hat{\mathbf{k}} \cdot \boldsymbol{x} \pm t## and for each component the general solution is ##\xi(\boldsymbol{x}, t) = f(p_+) + g(p_{-})##
Does wave phenomena arise from the third term in Feynman equation (21.1)?
At the end of 21-3 paragraph, Feyman boldy says that the complete theory of (classical) EM is in that box... but why doesn't he include the solutions of the homogeneous equations (the wave solutions)? Is really everything, that's a wave, in that third term of (21.1)?
I have here a (very respectable) book that includes them and it even says that, for bounded charge distributions, the Lienard-Wiechert potential are negligible far away from the sources, because they fall of faster then 1/r.
I'm confused.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
