artis
- 1,481
- 976
Hey, after doing some reading I stumbled across a few fundamental questions.1) Do all EM waves across the EM spectrum , if they travel through space have their E field and B field amplitudes exactly equal and in phase and shifted 90 degrees from one another?
If the answer is yes then...
2) In ordinary wires at DC or low frequency AC I can have any relationship between voltage and current, like have very low voltage and very high current or high voltage and low current, so taking the low voltage high current situation, if I made a very long antenna at low frequency, like a single phase electrical transmission wire and had low voltage but very high current run through the wire then how would the amplitudes of the radiated EM wave look like? I presume they would still have to be equal in amplitude ?
So I guess I'm asking is why do the amplitude of a traveling EM wave is equal for both E and B fields while the strengths of B and E field given in amperes and volts can vary dramatically in a circuit or wire?
Now I probably have asked enough but please one more.
3) Is it true that Em waves only travel transversely and not longitudinally?
If the answer is yes as I suppose it could be then consider this thought experiment example and please tell me the answer.
I glue a copper plate to a low frequency large amplitude excursion speaker, I charge the copper plate to some arbitrary positive or negative value.
I now have a static E field pointing out in space from the plate, I now apply a 50hz sine to the speaker and the voice coil and membrane start to resonate creating longitudinal pressure waves of sound in the air surrounding it.
What sort of EM wave will travel from the speaker plate?
