I Embedding Diagram of Weyl Metric in ##R^3##
Onyx
TL;DR Summary
Is it possible to make an embedding of the ##\phi##=constant slice of a Weyl metric in ##R^3##?
Is it possible to make an embedding of the ##\phi##=constant slice of a Weyl metric in ##R^3##? In particular, I'm thinking of a metric where the components are both ##\rho## and ##z## dependent.
Has anyone seen this question?
Onyx said:
a Weyl metric
This is a very general category, so I'm not sure your question is answerable unless you can narrow things down more.
Actually, forget about the Weyl metric for now. I am specifically trying to embed ##ds^2=U^2(dx^2+dy^2)##, where ##U=1+\frac{1}{\sqrt{(x-1)^2+y^2}}+\frac{1}{\sqrt{(x+1)^2+y^2}}##, into 3D Euclidean space. The only trouble is, the resulting function clearly does not have an indefinite integral, so there is the question of where to start the integration from.
Where does this line element come from?
One obvious issue is that the function ##U## is undefined at the ##(x, y)## points ##(1, 0)## and ##(-1, 0)##.
Yes, those are supposed to be the degenerate horizons of the black holes I think. I got this metric from a 2 black holed Majumdar-Papapetrou metric with black holes centered at the points you mentioned. I took the ##\phi=constant## slice and replaced what is usually ##p## and ##z## with ##x## and ##y##.
Okay, I think I figured out through pullback the form of h(x,y), the embedding function, is. It involves an indefinite integral whose answer is probably expressed with elliptic integrals in a way that I don't know. Maybe that question would be more at home in the pure math section of the website at this point.
