- #36
lugita15
- 1,554
- 15
OK, let me ask you this. Sometimes the polarizations are measured along a and b, and sometimes the polarizations are not measured along a and b. In either case, as you have agreed, the question "what would have been obtained had they measured the polarizations along a and b?" has a definite answer - although of course we may not always be able to find out the answer in the cases where we do not measure along a and b.billschnieder said:That is why I argue that in Bell's inequality |P(a,b) - P(a,c)| <= P(b,c) + 1, the terms P(a,b), P(a,c), P(b,c) can not all be measured simultaneously, therefore a genuine experimental test of Bell's inequality is impossible.
In words:
P(a,b) = What they would have obtained had they measured along a and b
P(b,c) = What they would have obtained had they measured along b and c instead
P(a,c) = What they would have obtained had they measured along a and c instead
Now you combine those and obtain an inequality -- good. Unfortunately it is impossible to test this experimentally because in any experiment that is doable, measuring anyone of them makes the others impossible to measure. So the experimentalists perform three different things on three different ensembles and fool themselves into thinking they are measuring the terms in Bell's inequallity.
Now consider the following two questions:
1. "What is the fraction of cases where the polarization measurements of the two particles would have yielded the same result had they measured along a and b?"
2. "In the subset of cases in which we measure along a and b, what is the fraction of cases where the polarization measurements of the two particles would have yielded the same result had they measured along a and b."
In some sense, the answer to question 1 is unknowable, because when we DON'T measure along a and b, we can't know what would have happened if we HAD measured along A and B. On the other hand, the answer to question 2 can be easily determined - we just look at all the cases in which the measurements were performed along a and b, and compute the percentage of these cases where the two measurements yielded the same result.
A crucial step in Bell's proof (and Herbert's proof) involves assuming that the answer to question 2 is the same as the answer to question 1 - in other words, assuming that the subset of cases in which we actually measure along a and b is a "representative sample" of the total set of cases. Is that the step in the logic that you dispute? If so, I can try to mount a defense for that step.
