MHB Emily's questions at Yahoo Answers regarding a solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The discussion revolves around calculating the volume of a solid formed by rotating a region bounded by the curves y=lnx, y=1, y=2, and x=0 about the y-axis. The volume is derived using the disk method, leading to the expression dV=πr²dy, where r is defined as x=e^y. The integral for the volume is formulated as V=π∫₁² e²ʸ dy, which is then simplified through substitution to V=(π/2)∫₂⁴ eᵘ du. Finally, applying the Fundamental Theorem of Calculus yields the volume as V=(π/2)(e⁴-e²).
MarkFL
MHB
Here is the question:
Please help with this simple integral question, thank you?
Write the integral for the volume of the solid obtained by rotating the region bounded by y=lnx, y=1, y=2, and x=0 about the y axis.
THANK YOU SO MUCH!
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Hello Emily,
First, let's plot the region to be revolved:
Using the disk method, we may write the volume of an arbitrary disk as follows:
$$dV=\pi r^2\,dy$$
where:
$$y=x=e^y$$
Hence:
$$dV=\pi \left(e^y \right)^2\,dy=\pi e^{2y}\,dy$$
Summing all the disks through integration, we may write:
$$V=\pi\int_1^2 e^{2y}\,dy$$
If we use the substitution:
$$u=2y\,\therefore\,du=2\,dy$$
we may write:
$$V=\frac{\pi}{2}\int_2^4 e^{u}\,du$$
Applying the FTOC, we find:
$$V=\frac{\pi}{2}\left[e^u \right]_2^4=\frac{\pi}{2}\left(e^4-e^2 \right)$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
