Emission and Absorption Spectra
In summary, when objects are heated, they emit specific wavelengths of light. However, this can vary depending on the conditions and can result in a range of colors. For example, hotter stars emit blue light while colder stars emit yellow light. Stars are mostly hydrogen, but other elements can also contribute to the emitted colors due to the conditions in a star's plasma. When we observe an absorption spectrum of sunlight, we see black gaps for different elements, but these same elements are also emitting light. This is due to the conditions in the star's atmosphere and the way light is absorbed and scattered. Overall, emission from the plasma is the dominant source of light, but the atmosphere can also contribute to the observed spectrum.
Nishantkumar19
When you heat things up, they emit specific wavelengths of light, right? Like when you heat up sodium, it emits yellow.
But don't things emit shorter wavelengths of light at higher temperatures? Like how hotter stars are blue and colder stars are yellow. Since stars are mostly hydrogen, shouldn't they be a mixture of just the colors we see in Hydrogen's emission spectrum?
When we see an absorption spectrum of sunlight, there are black gaps for the different elements. But those same elements are heated up in the sun, so they should be emitting light too, right?
Is it that the outer layers of stars are cooler? So the inner layers emit the light, and the outer layers block specific wavelengths of light by absorbing and then scattering them? But surely even the outer layers would be hot enough to be emitting their own light, right?
Please help!
Astronomy news on Phys.org
Be careful here: that is the case of you heat up a low-pressure sodium vapor. In other words, you have to be in conditions where atoms can still be seen as independent of one another. Simply going to high pressures, where collisions between atoms is more important, will give light that is closer to white. The Wikipedia article on sodium vapor lamps has nice illustrations.
Shorter wavelengths are due to higher-energy electronic excitations. Again, because of the conditions in which the atoms are, each line gets broaden due to collisions, the Doppler effect, etc. Also, in the case of a star, you have a plasma, where many atoms are ionized: it is not only hydrogen (and helium) atoms anymore. Stars are almost perfect blackbodies.
Emission is mostly from the plasma, which gives wide-spectrum blackbody radiation. That light passes through the star's atmosphere, which is much less dense and atoms can be seen as independent, that's why you get a discrete absorption spectrum. There will be also emission due to the atmosphere, but it is isotropic, so overall there is light "missing." This is the same thing you get in absorption spectroscopy in the lab.
Likes Nishantkumar19
Alright that clears it up a lot. Thanks!
It depends on the line. Some absorption lines are due to scattering, as already explained above, but others (like the famous Sodium "D" lines in the Sun) are due to absorption of the light from the hotter photosphere and replacing it with emission from cooler regions overlying the photosphere, just as you are thinking. Indeed, some lines even receive contribution from the chromosphere, which is hotter than the photosphere, and when the chromosphere gets thick enough (as can happen in solar flares), these lines are actually seen in emission.
Yes, but it's less than what they absorb, if the temperature is lower, and scattering always reduces the light because it bounces some of the light back down were it can be reabsorbed.
Related to Emission and Absorption Spectra
1. What is an emission spectrum?
An emission spectrum is a series of bright lines or bands of light that are produced when an element is excited and releases energy in the form of electromagnetic radiation.
2. How is an emission spectrum different from an absorption spectrum?
An emission spectrum is created when an element absorbs energy and releases it in the form of light, while an absorption spectrum is created when an element absorbs specific wavelengths of light and appears as dark lines against a continuous spectrum of light.
3. What can we learn from an emission spectrum?
An emission spectrum can provide information about the elements present in a substance, as each element has a unique emission spectrum. It can also provide information about the energy levels of electrons in an atom.
4. What causes the different lines in an emission spectrum?
The different lines in an emission spectrum are caused by the different energy levels of the electrons in an atom. When the electrons transition from a higher energy level to a lower one, they release energy in the form of light, producing the distinct lines in the spectrum.
5. How is emission and absorption spectroscopy used in scientific research?
Emission and absorption spectroscopy are important tools in scientific research, particularly in the fields of chemistry, physics, and astronomy. They can be used to identify and analyze the composition of substances, study the energy levels of atoms and molecules, and provide insights into the properties of distant objects in the universe.
  • Astronomy and Astrophysics
