MHB Emptying and filling a tank word problem.
  • Thread starter Thread starter paulmdrdo1
    Tank Word problem
The problem involves two filling pipes and one draining pipe, with the filling times of 45 minutes and 30 minutes, respectively. When both filling pipes are open, the tank fills in 27 minutes despite the drain. The calculations confirm that the draining pipe takes 54 minutes to empty the tank alone. The discussion clarifies that the filling rate exceeds the draining rate, allowing the tank to fill even while draining occurs. This understanding resolves the confusion about simultaneous filling and emptying.
paulmdrdo1
I just want to make a sanity check here.
here's the problem
One pipe can fill a tank 45min and another can fill it in 30 min. If these two pipes are open and a third pipe is draining water from the tank, it takes 27 min to fill the tank. how low will it take the third pipe alone to empty a full tank?
this is how I solved it. But I'm dubious about the real life scenario I'm picturing in my head right now.
$\frac{1}{45}\times 27+\frac{1}{3}\times 27-\frac{1}{t}\times 27=1$ where t is the time required for the third pipe to empty the tank by itself.
answer $t=54$min
if the Filling and the emptying of the tank is simultaneously happening how can we say that the tank will reach the full state? I'm confused! please help me picture this correctly.
Mathematics news on Phys.org
Hello, paulmdrdo!
How long will it take the third pipe alone to empty a full tank?
This is how I solved it. But I'm dubious about the real life
$\frac{1}{45}\cdot 27+\frac{1}{3}\cdot 27-\frac{1}{t}\cdot 27\;=\;1$ . Correct!
Answer: t = 54 min. . Right!
If the filling and the emptying of the tank is simultaneously
happening, how can we say that the tank will reach the full state?
Think about it . . .
Pipes A and B are filling at a faster rate than pipe C is draining.
Of course, the tank will eventually be filled.
Another way to look at it is that in 270 minutes, the first pipe can fill 6 tanks, the second pipe can fill 9 tanks and with the drain open 10 tanks will be filled. This means the drain can empty 9+6-10=5 tanks in 270 minutes or 1 tank every 54 minutes.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
