Energy and momentum operators in QM
In summary: The Hamiltonian operator is intimately related to the total energy of a system. It is merely a matter of calling it the Hamiltonian instead of energy operator.
McLaren Rulez
292
Hi,
I understand that we use [itex]i\hbar\partial/\partial t[/itex] and [itex]-i\hbar\nabla[/itex] for the energy and momentum operator but I would like to know how this identification is made.
I can see that it works for a wave of the form [itex]e^{i(kx-\omega t)}[/itex] and using the relation [itex]E=\hbar\omega[/itex] and the relation [itex]p=h/\lambda[/itex].
But what about everything else? How did physicists come to the conclusion that the general energy and momentum operator are of the form mentioned above?
Thank you very much.
There's no energy operator, rather the Hamilton operator. And the way these operators <look> in quantum mechanics (what they are represented through) depends a lot on the system under analysis. The so-called <canonical commutation relations> set forth at the end of the 1920's, within the properly defined mathematical environment (the theory of separable Hilbert spaces), lead inevitably to a representation of the momentum operator in coordinate space as [itex] -i\hbar \nabla [/itex] (Schroedinger 1926, Stone 1930 and von Neumann 1931).
As for the explicit form of the Hamilton operator, this is largely dependent on the quantization scheme and on whether the quantum system has a classical counterpart whose Hamiltonian formalism is fully known.
Dextercioby, thank you for the quick reply.
So ultimately, how did Schrodinger write down his equation? I thought the motivation behind it was something along the lines of my original post.
I understand how [itex][x\ p]=i\hbar[/itex] leads to the momentum operator but what about the Hamiltonian operator? Since my QM text starts off with the Schrodinger eqaution, I would like to know a little about how Schrodinger himself came up with it.
Thank you.
P.S. Could you also tell me what is the difference between the energy operator and the Hamiltonian operator? I was under the mistaken assumption that they were the same thing.
McLaren Rulez said:
Hi,
Momentum is the generator of the space translation, energy is the generator of the time translation of a state. From there you can see why they have the form they have.
Look for example here
http://www.hep.upenn.edu/~rreece/docs/notes/derivation_of_quantum_mechanical_momentum_operator_in_position_representation.pdf
or google translation generator operator quantum...or something like that
Essentially he built on L. de Broglie's idea of matter waves for particles (p=h \nu) and used the theory of electromagnetic waves as a starting point in deriving his equation. He ended up with his famous equation whose predictions he successfully tested against a model for the hydrogen atom (obtained the countable nature of negative energy levels).
His 4 original articles in German in the <Annalen der Physik> have been translated into English (a book, google for <Collected papers on wave mechanics>) and he also published a lucid summary of his work in the American journal <The Physical Review> in 1926.
Thank you.
There's no energy operator, but merely the Hamiltonian operator which is somehow related to the Hamiltonian of the classical theory (where the latter exists).
On a superficial level, all classical observables of the Hamiltonian formalism are <promoted> to linear operators on a linear space and above all one postulates the Schroedinger equation for the <wavefunction> (2nd order partial differential equation).
For a beginner's level, it's the usual approach, since the knowledge of mathematics is kept to a minimum.
P.S. From his 4 articles one sees that he was aware of the <Dreimaennerarbeit> of Heisenberg, Jordan and Born (1925) which founded <matrix mechanics>. In 1926 he went on to prove the equivalence of matrix and wave mechanics in a separate paper.
Thank you. I will take a look at the original papers when I get the chance as well as the translation operator link.
One final question: If the Hamiltonian operator is related to the classical Hamiltonian, then it must have something to do with the total energy, right? Is it just a matter of calling it the Hamiltonian instead of energy operator or is there something deeper that I am missing here?
Thank you once again.
Yes, the convention is to name it as Hamilton operator.
Thank you very much dextercioby.
FAQ: Energy and momentum operators in QM
What is the energy operator in quantum mechanics and how is it defined?
The energy operator in quantum mechanics is a mathematical representation of the total energy of a system. It is defined as the Hamiltonian operator, which represents the sum of the kinetic and potential energies of the system. In mathematical notation, it is represented as Ĥ.
How is the momentum operator defined in quantum mechanics?
The momentum operator in quantum mechanics is a mathematical representation of the momentum of a particle. It is defined as the gradient of the position operator, which represents the position of a particle in space. In mathematical notation, it is represented as p̂ = -iħ∇.
What is the commutator of the energy and momentum operators?
The commutator of the energy and momentum operators is a mathematical operation that determines how the two operators behave when applied to the same wavefunction. In quantum mechanics, the commutator is equal to -iħ times the position operator. This relationship is known as the Heisenberg uncertainty principle.
How are the energy and momentum operators related to the time evolution of a quantum system?
The energy and momentum operators play a crucial role in the time evolution of a quantum system. The energy operator is used to calculate the total energy of a system, while the momentum operator is used to determine the velocity and direction of a particle. Together, these operators help to describe how a quantum system changes over time.
Can the energy and momentum operators be measured directly in experiments?
No, the energy and momentum operators cannot be measured directly in experiments. In quantum mechanics, these operators are represented by mathematical equations that describe the properties of a system. While the effects of these operators can be observed and measured indirectly, the operators themselves cannot be directly measured.
