Energy and power supplied by a bicyclist
In summary: Your work for the rest of parts (a) and (b) looks correct to me regarding method.In summary, The cyclist supplies energy to the pedal by turning the shaft at a speed of ω. The average power output is given by the work difference per unit time, which is 55.20 W.
welssen
In bicycling, each foot pushes on the pedal for half a rotation of the pedal shaft; that foot then rests and the other foot takes over. During each half-cycle, the torque resulting from the force of the active foot is given approximately by τ = τ0 sin ωt, where τ0 is the maximum torque and ω is the angular speed of the pedal shaft (in s-1 as usual). A particular cyclist is turning the pedal shaft at ω=70.0 rpm, and at the same time τ0 is measured at 38.5 N•m.
Find:
(a) the energy supplied by the cyclist in one turn of the pedal shaft and
(b) the cyclist's average power output.
Work:
W = τθ, with θ the angular displacement;
Work-energy theorem:
W= ΔKE = Energy supplied by the cyclist
For (a) I thought of using the work-energy theorem the following way:
E=τ0 sin(ωt)θ
with:
- θ=2π rad=one revolution
- t=θ/ω
So I get E = 38.5*sin(ω*2π/ω)*2π = 0 !
This is not really what I expect...
For (b) there may be a rotational version of P=F*v that is P=τω.
Thanks for your help
Welcome to PF!
E=τ0 sin(ωt)θ
Since the torque depends on time, you will need to use calculus.
Yes, but this would give the instantaneous power. You want the average power.
Likes welssen
Thank you!
So I apply the following integral from 0 to 2π:
W=∫τ0 sin(ωt)dθ
Then :
dθ/2π = dt/T (T:=total time=2π/ω) ⇒ dθ=ω dt
⇒ W = ∫τ0 sin(ωt)/ω dt = -τ0 cos(ωt)/(ω^2)
Evaluating the integral from 0 to 2π gives 0, again. Or should I integrate from 0 to π for the up-down movement?
Thanks again for your answer
welssen said:
So I apply the following integral from 0 to :
W=∫τ0 sin(ωt)dθ
Note that the expression τ0 sin(ωt) only holds for half a cycle. (This expression would give a negative torque for the second half of the cycle. But this doesn't happen. Instead, the other foot takes over.)
Then :
How did ω get into the denominator?
Yes, integrate θ from 0 to π; or integrate t from 0 to the time corresponding to θ = π.
Likes welssen
Very nice, thanks!
This was a mistake indeed, it's supposed to be in the nominator.
So just a recap for (a):
W = ∫τ0 sin(ωt)dθ = -τ0 cos(ωt) → from 0 to π gives → Supplied Energy = W = τ0 cos(ωt)
We must consider that ω in the cos term has unit s^(-1) so we multiply it by 2π to have it in rad/s.
Numerically,
ω=70 rpm = 7.33 rad/s
t=π/ω=0.429 s
So E = 38.5*cos(2π 7.33⋅0.429) = 23.68 J.
So the energy supplied for one turn is:
E = 47.36 J.
(b) The average power is the work difference per unit time which leaves:
P = ΔW/(2*Δt) = 47.36/(2*0.429) = 55.20 W.
(And here Δt is multiplied by 2 for both feet movements)
Hopefully this is correct.
OK
I don't think you evaluated at the limits correctly. Otherwise, your work for the rest of parts (a) and (b) looks correct to me regarding method.
Just caught something else.
t=π/ω=0.429 s
So E = 38.5*cos( 7.33⋅0.429) = 23.68 J.
Why the factor of 2π? Note that t=π/ω tells you that ωt = π. That's all you need to evaluate cos(ωt).
Thanks.
Oh I see... I thought that, as ω is specified to be given in s^(-1), we were expected to convert it into rad/s (so multiplying it by 2π)... But OK I understand it now.
So actually
(a) E = 2*38.5 = 77 J.
(b) P = 89.7 W.
welssen said:
So actually
(b) P = 89.7 W.
I think these answers are off by a simple factor due to the fact that you didn't evaluate W = ∫τ0 sin(ωt)dθ = -τ0 cos(ωt) correctly at the lower limit (t = 0).
Related to Energy and power supplied by a bicyclist
1. How does a bicyclist generate energy to power their bike?
A bicyclist generates energy through pedaling. As the cyclist pushes down on the pedals, the force is transferred to the chain, which then turns the wheels of the bike. This rotational motion creates kinetic energy, which powers the bike forward.
2. What type of energy does a bicyclist use?
A bicyclist primarily uses muscular energy, which is the energy generated by the muscles in the body. This energy is converted into kinetic energy to power the bike.
3. How much power does a bicyclist produce?
The amount of power a bicyclist can produce varies depending on factors such as their fitness level, the terrain, and the type of bike. On average, a cyclist can produce anywhere from 100-300 watts of power, with professional cyclists being able to produce even more.
4. How does a bicyclist conserve energy while riding?
A bicyclist can conserve energy by using proper form and technique while pedaling, maintaining a consistent pace, and using gears to their advantage. They can also conserve energy by taking breaks and consuming energy-rich snacks or drinks during long rides.
5. How does a bicyclist's power output affect their speed?
A bicyclist's power output directly affects their speed. The more power they produce, the faster they can go. However, other factors such as wind resistance, terrain, and the weight and aerodynamics of the bike also play a role in determining the cyclist's speed.
