Energy and the Friedmann Equation
The potential energy of each shell can be written as dU = -GdMm/r, where G is the gravitational constant, m is the mass of the shell, and r is the distance between the shell and the center of the sphere. Therefore, the total potential energy of the sphere can be written as U = -∫dU = -∫GdMm/r = -G∫ρ4πr^2drm/r. Similar to the previous case, we can simplify this integral by using the relation dV = 4πr^2dr and the fact that the mass of each shell is equal to the mass of the sphere divided by its volume
black_hole
75
To relate E to the total energy of the expanding sphere, we need to integrate over
the sphere to determine its total energy. These integrals are most easily carried out
by dividing the sphere into shells of radius r, and thickness dr, so that each shell
has a volume dV = 4πr^2dr .
(b) (10 points) Show that the total kinetic energy K of the sphere is given by
K = ck * MRmax,i2{1/2*d2r/dt2}
where cK is a numerical constant, M is the total mass of the sphere, and Rmax,i
is the initial radius of the sphere. Evaluate the numerical constant cK.
(c) (10 points) Show that the total potential energy of the sphere can similarly be
written as U = cU*MR2max,i {-4∏/3 Gρi/a}
(Suggestion: calculate the total energy needed to assemble the sphere by bringing in one shell of mass at a time from infinity.) Show that cU = cK, so thatthe total energy of the sphere is given by
Etotal = cK*MR2max,iE .
dV=4∏r^2dr
Rather at a loss here, I tried starting out with their suggestion but given what I know E to be from the Freidmann eqs I don't see how that would work. These results are kind if intuitive, so I don't see how to shpw them per se.Like I've tried fiddling with integrals to little avail...something like k = 1/2mv^2 m = 4/3 ∏ri^3pi ??
Thank you for your interesting post. To begin with, I would like to clarify that the equations you have mentioned in your post do not relate to the total energy of the expanding sphere. The equation for the total energy of the sphere is given by Etotal = K + U, where K is the kinetic energy and U is the potential energy. In this response, I will guide you through the steps to derive the equations for K and U, and evaluate the numerical constants cK and cU.
To start with, let us consider the total kinetic energy K of the sphere. As mentioned in the problem, we can divide the sphere into shells of radius r and thickness dr. The mass of each shell can be written as dM = ρdV = ρ4πr^2dr, where ρ is the density of the sphere. The total mass of the sphere can be written as M = ∫dM = ∫ρ4πr^2dr. Now, the kinetic energy of each shell can be written as dK = 1/2dMv^2, where v is the velocity of the shell. Therefore, the total kinetic energy of the sphere can be written as K = ∫dK = ∫1/2dMv^2 = 1/2∫ρ4πr^2drv^2. This integral can be simplified by using the relation dV = 4πr^2dr and the fact that the velocity of each shell is equal to the velocity of the center of mass of the sphere, which can be written as v = 1/2d2r/dt2. Therefore, we get K = 1/2∫ρdVv^2 = 1/2∫ρ4πr^2dr(1/2d2r/dt2)^2 = cKMRmax,i^2(1/2d2r/dt2)^2, where cK is a numerical constant. Evaluating this integral, we get cK = 4/3. Therefore, the total kinetic energy of the sphere can be written as K = 4/3MRmax,i^2(1/2d2r/dt2)^2.
Next, let us consider the total potential energy of the sphere. As suggested in the problem, we can calculate the potential energy by bringing in
Related to Energy and the Friedmann Equation
1. What is the Friedmann Equation?
The Friedmann Equation is a fundamental equation in cosmology that describes the evolution of the universe. It is named after Alexander Friedmann, a Russian mathematician who first derived it in 1922.
2. How does the Friedmann Equation relate to energy in the universe?
The Friedmann Equation is a mathematical expression that relates the distribution of matter and energy in the universe to its expansion rate. It takes into account the effects of both matter and energy on the overall dynamics of the universe.
3. What does the Friedmann Equation predict about the future of the universe?
The Friedmann Equation predicts that the fate of the universe is determined by the balance between the density of matter and energy. If the density is high enough, the universe will eventually collapse in a "Big Crunch." If the density is too low, the universe will continue to expand indefinitely.
4. How does the Friedmann Equation support the theory of the Big Bang?
The Friedmann Equation is a key component of the Big Bang theory, as it describes the expansion of the universe from a singularity (infinitely small and dense point) to its current state. It also helps to explain the cosmic microwave background radiation, which is considered a remnant of the Big Bang.
5. Can the Friedmann Equation be applied to other universes or systems?
While the Friedmann Equation was originally derived for our observable universe, it has also been used to study other hypothetical universes and even other systems such as black holes. However, its applicability may be limited by the assumptions and parameters used in its derivation.
  • Quantum Physics
