Energy balance on metallurgical furnace
In summary: I think what they were trying to say is that the furnace was adding heat to the system, but the excess air was adding more heat to the furnace than was needed.
MexChemE
237
55
Pure iron sulfide (FeS2) is fed into an Herreshoff furnace at 25 °C. An 83% of excess air is also fed into the furnace at 25 °C. The solid product consists only of Fe2O3. The solid product reaches a temperature of 1832 °C, and the exhaust gases (8.7% SO2, 9.8% O2, 81.5% N2) reach a temperature of 1472 °C. Determine the amount of heat lost (Q < 0) by the furnace due to radiation, per tonne of pyrite loaded.
Given solution: Q = +3,786,595 BTU per tonne of pyrite
(First off, there seems to be an inconsistency between the problem statement and the given solution; I'm not showing all of my procedure and calculations since I got very close numerically to the given solution, what I want to discuss is said inconsistency)
Process block diagram attached
Q = ΔH (Energy balance on the furnace)
FeS2 + 2.75 O2 → 0.5 Fe2O3 + 2 SO2
First off, I started by stablishing a basis of M1 = 1 mol. I performed a mass balance on the furnace in order to determine the rest of the molar flows. These were
M2 = 23.95 mol
M3 = 0.5 mol
M4 = 23.2 mol
It was a pretty straightforward balance, since I'm told the 100% of iron sulfide reacts to yield ferric oxide. Next, I set up the energy balance on the furnace
[tex]Q = \Delta H = \Delta H_{Rx}^° + \Delta H_3 + \Delta H_4[/tex]
Where
[itex]\Delta H_{Rx}^°[/itex] is the standard enthalpy of the roasting reaction (maximum amount of heat generated in the furnace)
[itex]\Delta H_3[/itex] is the amount of heat needed to raise the solid product's temperature to 1832 °C
[itex]\Delta H_4[/itex] is the amount of heat needed to raise the exhaust gases' temperature to 1472 °C
I got the enthalpies of formation of reactants and products in charts provided by the professor. Molar heat capacities of the products were also found in another set of charts provided by the professor. For the heat capacity of the exhaust gases, I used the heat capacities of each gas and their molar fractions to calculate the average molar heat capacity of the mix. My results were
[tex]\Delta H_{Rx}^° = -197650 \ cal[/tex]
[tex]\Delta H_3 = (0.5 \ mol) \left(43.7 \ \frac{cal}{mol \ K} \right)(1832 \ °C - 25 \ °C) = 39482.95 \ cal[/tex]
[tex]\Delta H_4 = (23.2 \ mol) \left(8.3 \ \frac{cal}{mol \ K} \right)(1472 \ °C - 25 \ °C) = 278634.32 \ cal[/tex]
Next, I calculated Q, but this first result is for 120 grams (1 mol) of iron sulfide loaded. I did some calculations in order to adjust the result for a tonne of sulfide roasted.
[tex]Q = -197650 \ cal + 39482.95 \ cal + 278634.32 \ cal = \frac{120467.27 \ cal}{120 \ g}[/tex]
[tex]Q = \frac{478.04 \ BTU}{120 \ g} = 3.98 \ \frac{BTU}{g}[/tex]
[tex]Q = 3.98 \ \frac{BTU}{g} (1,000,000 \ g) = 3,980,000 \ BTU[/tex]
Now, if the problem statement tells me heat is being lost by the furnace due to radiation, I would expect a negative result of Q, not positive. However, this is the correct result for the problem, even though it doesn't agree with the physical situation. What I'm guessing is that the problem (and the process modeled within) was badly designed by the professor. 83% excess of air seems a lot to me; the exhaust gases alone need a greater amount of the maximum generable heat by the process in order to reach 1472 °C. My understanding is that a real furnace operating under these conditions would need a heat input of 3.9 mega BTU in order to carry out the process, but real furnaces are supposed to release a large amount of heat, not consume it. What I'd do to fix this inconsistency is to lower the amount of air fed into the furnace, so the exhaust gases don't consume more heat than the amount generated by the process. I guess it's an obvious choice. I hope my analysis of the situation is correct.
Thanks in advance for any input!
The value I get for M4 is 20.9 moles. That might account for the difference in the magnitude of Q.
They can't mean heat lost in the problem statement, because the furnace certainly adds heat. Otherwise, why is it called a furnace.
Chet
Required amount of oxygen is 2.75 mol, times 1.83 yields 5.03 mol, which is the amount of O2 fed. 5.03 mol times the ratio of nitrogen to oxygen (0.79/0.21) yields 18.92 mol of N2. The amount of O2 exiting the furnace is 5.03 mol - 2.75 mol = 2.28 mol, plus 18.92 mol of N2 and 2 mol of SO2 generated add up to 23.2 mol.
Maybe I'm confusing the way this kind of furnaces are analyzed (from an energy balance point of view) versus industrial process furnaces (heaters), where your desired product is a large (and negative) magnitude of Q. In a roasting furnace your desired product is to make the sulfide react, by raising its temperature. But a metallurgical furnace still loses heat by radiation, doesn't it? And if this specific furnace needs 3.9 mega BTU, how do you supply the heat? What is actually happening in a roasting furnace? Is the sulfide actually burning? If it does, how does it ignite?
Oops. I forgot to include the oxygen in the exit stream. Sorry.
It seems to me you analyzed this problem correctly. I don't know what else to say.
Chet
Likes MexChemE
I will also add, that even if the furnace is losing heat via radiation, it is not possible to account for it just with the information provided in the problem statement. The amount of heat lost by radiation is included in the value of Q, I guess, but impossible to calculate without the proper data. The bigger the heat loss due to radiation is, the bigger the amount of heat we need to provide the furnace with. So I guess the issue lies within the problem statement's wording.
I agree.
Chet
Likes MexChemE
Related to Energy balance on metallurgical furnace
1. What is energy balance on metallurgical furnace?
Energy balance on metallurgical furnace is a process that involves calculating the total energy that enters and leaves a furnace, and ensuring that the amount of energy is balanced to maintain the desired temperature and efficiency of the furnace.
2. Why is energy balance important for metallurgical furnaces?
Energy balance is important for metallurgical furnaces because it helps to optimize the performance of the furnace and ensure that it operates at its maximum efficiency. This not only saves energy but also reduces operating costs and minimizes environmental impact.
3. How is energy balance calculated for metallurgical furnaces?
Energy balance is calculated by considering all the sources of energy that enter the furnace, such as fuel, air, and electricity, and all the ways that energy is used, such as heating, melting, and chemical reactions. The total energy entering the furnace should be equal to the total energy leaving the furnace, which is primarily in the form of heat.
4. What factors can affect the energy balance on a metallurgical furnace?
Several factors can affect the energy balance on a metallurgical furnace, including the type and quality of fuel used, the design and condition of the furnace, the temperature and composition of the materials being processed, and the efficiency of heat transfer within the furnace.
5. How can energy balance be improved on metallurgical furnaces?
Energy balance can be improved on metallurgical furnaces by regularly monitoring and optimizing furnace operations, using energy-efficient technologies and equipment, and minimizing heat losses through insulation and other measures. Additionally, using alternative energy sources, such as renewable fuels, can also help improve energy balance on metallurgical furnaces.
  • Mechanical Engineering
9K
  • Materials and Chemical Engineering
