Energy Bands and Molecular Orbitals
The discussion centers on the relationship between molecular orbitals (MO) and energy bands in solid-state physics. It highlights the confusion surrounding why potassium (K) behaves as a conductor despite having a fully filled σ state, while silicon (Si), with partially filled π states, does not exhibit similar conductive properties. The conversation emphasizes the difference between the band structures of diatomic molecules and those of infinite crystals, questioning their comparability. To gain a clearer understanding, it is suggested to study Bloch's theorem and conduct model calculations on one-dimensional atomic chains. This approach aims to clarify the concepts of MO and energy band conduction.
ABhattacharya
Hello, a newbie here. I need to understand the relationship between MO and Energy Bands.
Although i have searched and researched about this topic in Google, but i am yet to understand this part clearly.
It is said that Energy Bands occur as the number of MO increase due to the various atoms that are interlinked in a crystal structure.
But i can't help but wonder.
While K has its σ state fully filled and its σ* state empty, and yet behaves as a conductor
But Si has ∏px and ∏py states partially filled which means when bands form, Si should have some bands which are partially filled and hence should be good conductors while Na should behave more of a semiconductor way... but it is just the opposite. Why?
The diagram you show seems to be for diatomic molecules while the band structure refers to infinitely large crystals. Why do you think the two are comparable?
Then what should i do to get a clearer picture of the MO and Energy Band conduction??
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
17K
