Energy Changes due to Friction in a 1st Year Course
In summary, the conversation discusses modifications to a first year Physics course for students with little background in Physics. One modification being considered is how to account for kinetic friction, with the proposed change being to include it as a change in internal energy. However, this introduces complexity and requires careful discussion. Another approach is to distinguish between active and passive forces, and to discuss the range of normal force that results in constant motion of an object.
tzonehunter
24
I teach a first year Physics course. The incoming students (grades 10-12) have little to no Physics background. We are making some modifications to our work and energy unit. One modification that has been discussed is what to do about kinetic friction. At present, we account for friction as a negative change in mechanical energy by calculating a pseudo-work term (-fkΔx). We don't look at examples such as a car peeling out from a stop sign. Again, this is a 1st year Physics course...
We have considered changing our accounting of energy changes due to friction as a change in internal energy. For the examples we consider, we would state that ΔEinternal = fkΔx in the absence of thermal energy transfer in / out of the system. However, should we include the surface in the system as well? Is this getting to be a little too much for the 1st year student?
I'm wondering what all of you do about this.
Thanks.
Science news on Phys.org
According to the Feynman Lectures on Physics, Volume 1, section 12-2 the laws of friction taught in introductory physics courses are not fundamental laws of nature but rather statistical approximations to complicated phenomena that (at the time that writing) are not completely understood.
Problems treating frictional force as a constant are mathematical contrivances that make textbook problems more challenging. There is certainly a tradition in the teaching of mechanics to pose problems that force the student to include dynamic friction as a term in calculating the total force on an object. On the basis that a Physics I course should make students comfortable with the problems traditionally taught in a Physics 2 and subsequent courses, the question becomes whether you should prepare students for textbook problems in future that include friction in accounting for total internal energy. Are such problems as ubiquitous in future courses as the familiar problems of objects sliding down inclined planes with friction etc. that are traditional in a course on mechanics?
Likes Dr. Courtney
I scanned through a compendium of old AP Physics B free response problems that addressed Work and Energy. About 50% of those included a portion that required students to calculate or account for energy changes due to sliding friction.
Whether or not it is appropriate to model kinetic friction as a constant force is an interesting debate. Numerous introductory mechanics questions include constant forces exerted over a non-trivial time interval. In reality, this is nearly impossible to observe. For example, we worked on a class demo that involved pulling a low-friction Pasco dynamics cart along an aluminum track using a modified Atwood's setup. We expected to observe a somewhat constant tension force. What we observed was a tension force that changed by +/-20% due to a standing wave set up in the string when the cart was released. We believe this was due to the sudden drop in tension when the cart was released from rest, similar to plucking a guitar string. We were surprised by the degree to which the tension force changed due to this standing wave.
Here's the setup referenced above:
https://drive.google.com/file/d/0Bw3jRUYuv9uwbUIzdzFDanJqVlU/view?usp=sharing
Here's real data from this demonstration:
https://drive.google.com/file/d/0Bw3jRUYuv9uwbDdTdm03VzE0Tm8/view?usp=sharing
Likes BvU
You'd have to include the surface since it absorbs some of the energy and heats up.
The distinction between work and pseudo-work would probably be lost on your students as it's pretty subtle, but I don't think they should have a problem with understanding that the decrease in mechanical energy of the object is balanced by an increase in thermal energy of the object and the surface.
Likes scottdave and PhanthomJay
Thanks.
Some good comments already, I'll just add that from my perspective, your proposed change introduces significant and largely unnecessary complexity that will require a lot of careful discussion: for example, what exactly is "internal energy"? How do you define the "surface"? What about non-thermal energy transfers? Where does the fkΔx energy go, if conservation of energy holds?
I recognize the shortcomings of pseudo-work- Arons' book "Teaching Introductory Physics" has some excellent comments regarding teaching friction. One alternate approach is to distinguish between 'active' and 'passive' forces- passive forces are those that adjust themselves is response to active forces (deformation of a spring, deformation of a table when a load is placed on it, friction..), and the passive force cannot increase indefinitely- the spring/table will break, one object will slip over another, etc. A possible example to discuss is pushing a book (or some other object) against a wall- the normal force is then disconnected from weight, and is also easily adjustable. It could be possible to frame the discussion in terms of what range of normal force results in constant motion of the book (or the conditions under which the book remains motionless). Comparing the book/wall system with a low-friction system like wet ice on wet glass may also be useful.
Finally, IMO there's nothing wrong with discussing the fact that there is not yet a full microscopic understanding of the 'cause' of friction (or of any dissipative process), and further, it could be helpful to initiate a discussion about 'dissipation' as it eventually connects to changes of entropy during a process.
This is easily demonstrated by quickly rubbing hands together and feel them get warm, as one example. The harder you press (more force), it will get warmer. Also the more times you rub them (longer distance) it will get warmer as well.
Related to Energy Changes due to Friction in a 1st Year Course
1. What is friction and how does it affect energy changes?
Friction is a force that resists motion between two surfaces in contact. It converts kinetic energy into thermal energy, resulting in a decrease in the overall energy of a system.
2. Can friction ever result in an increase in energy?
No, friction always results in a decrease in energy due to the conversion of kinetic energy into thermal energy. This is known as the law of conservation of energy.
3. How does the surface texture affect the amount of friction?
The surface texture plays a major role in the amount of friction between two surfaces. Rougher surfaces have more points of contact, resulting in a higher amount of friction compared to smoother surfaces with fewer points of contact.
4. How does the force of friction depend on the mass of the objects in contact?
The force of friction is directly proportional to the mass of the objects in contact. This means that as the mass of the objects increases, the force of friction also increases.
5. How can we reduce the effects of friction in a system?
One way to reduce the effects of friction is by using lubricants, such as oil or grease, to create a slippery layer between two surfaces. Another way is by using smoother surfaces or reducing the weight of the objects in contact.
  • STEM Educators and Teaching
  • Biology and Medical
