I Energy conditions and non-physical phenomena
accdd
Is the inability to exceed the speed of light a consequence of general relativity?
Is the fact that no energy is created from empty space a consequence of general relativity?
Or are they both constructions deriving from the energy conditions imposed to have solutions to Einstein's equations that are compatible with observations?
You need to define what you mean by "exceeding the speed of light".
You need to define what you mean by "no energy is created from empty space".
Likes vanhees71 and accdd
Locally, nothing can exceed the speed of light.
If I take a small volume I don't expect it to generate stuff out of a vacuum.
This in essence follows from 4-momentum being non-spacelike.
This, in the form ##\nabla_\mu T^{\mu\nu}## is a direct consequence of varying the Einstein-Hilbert action with an additional term to describe the matter fields (and thereby generating the stress-energy tensor). The Einstein field equations resulting from varying the Einstein-Hilbert action are on the form ##G_{\mu\nu} = C T_{\mu\nu}##, where ##C## is a constant and the divergence of the Einstein tensor ##G_{\mu\nu}## is equal to zero.
However, "global" energy is generally not conserved in general relativity as demonstrated, e.g., by FLRW cosmologies.
Sean Carroll in Spacetime and Geometry writes (4.6, last section):
[Energy conditions ... serve to prevent other properties that we think of as "unphysical", such as energy propagating faster than the speed of light...]
What does this means?
I suggest looking at the basic descriptions of different energy conditions in relativity. They are all concerned with the stress-energy tensor and are at varying degrees of strictness. For example, look at https://en.wikipedia.org/wiki/Energy_condition under "Mathematical statement".
The statement that relates to the flow of energy is the dominant energy condition which relates to ##T_{ab} Y^b## where ##Y## is a time- or light-like vector field. The resulting 4-vector describes energy density and flow.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
