Energy Conservation and Coefficient of Restitution
In summary, the conversation discusses a scenario where a car and a pickup truck collide in a parking lot. The initial velocities and masses of the vehicles are given, and the problem asks for the change in internal energy and the coefficient of restitution for the collision. The solution involves using the conservation of momentum equation and the formula for coefficient of restitution, and ultimately results in a velocity of 2.78 m/s for the car and a coefficient of restitution of 0.52.
B3NR4Y
A 1300-kg car is backing out of a parking space at 5.0 m/s . The unobservant driver of a 1700-kg pickup truck is coasting through the parking lot at a speed of 3.2 m/s and runs straight into the rear bumper of the car.
(a). What is the change in internal energy of the two-vehicle system if the velocity of the pickup is 1.5 m/s backward after they collide?
(b). What is the coefficient of restitution for this collision?
[itex] p_{total, \, initial} = p_{total, \, final} = m_{c} v_{ci} + m_{p} v_{pi} = m_{c} v_{cf} + m_{p} v_{pf} [/itex]
Conservation of momentum, you can use it to solve for the velocity of the car after the collision.
[itex] e = -\frac{v_{12, \, f}}{v_{12, \, i}} [/itex]
where v12 is the car's velocities relative to each other. e is the coefficient of restitution.
[itex] K = \frac{1}{2} mv^{2} [/itex]
[itex] \Delta K = -\Delta E [/itex]
To start the problem, I drew a diagram and defined my coordinate system such that the initial velocity of the pickup is in the positive direction. Since the author of this textbook ignores two dimensional motion for 10 chapters, the collision is one-dimensional therefore the truck drives directly into the rear of the car. So, the initial velocity of the car is -5.0 m/s, because if is coming toward the pickup. The pickup is going backward after the collision, therefore having negative velocity. So I set up my momentum equation,
[itex] (1300 kg)(-5.0 m/s) + (1700 kg)(3.2 m/s) = (1300 kg)v_{c, \, f} + (1700 kg)(-1.5 m/s) [/itex]
I got the initial total momentum to be -1060 and used algebra (adding 2550 kg m/s to both sides and dividing by 1,300) to arrive at my answer of ~2.78 m/s for the velocity of the car. Using my calculator I confirmed it agreed with the conservation of momentum (same magnitude, just different directions). I started the problem with the easiest question, which was (b). and got 0.52, incorrect. I set up my problem:
[itex] e = \frac{2.78+1.5 (m/s)}{8.2 (m/s)} [/itex]
The denominator is flipped because I distributed the negative sign, but got the same answer if I didn't so it doesn't matter much. And I used the real, not rounded, value for the velocity of the car so that is not the source of my error.
If the posterior velocities are -2.78 and -1.5, what is the posterior relative velocity?
~-1.25 m/s, I would say
Well, 1.28, not caring about the sign for now; not 2.78+1.5, as in your original post.
I would like to commend you on your thorough and detailed approach to solving this problem. It is clear that you have a good understanding of conservation of momentum and the concept of coefficient of restitution.
In order to solve for the coefficient of restitution, we need to use the equation:
e = - v12f / v12i
where v12f is the final relative velocity of the two vehicles and v12i is the initial relative velocity. In this case, the initial relative velocity is (5.0 m/s + 3.2 m/s) = 8.2 m/s, since they are moving in opposite directions.
Using the value you calculated for the final velocity of the car (2.78 m/s) and the given final velocity of the pickup (-1.5 m/s), we get:
e = -(-1.5 m/s) / (8.2 m/s) = 0.183
This is the correct value for the coefficient of restitution. It is important to note that the negative sign in front of the initial relative velocity is already taken into account when we use the final velocities.
Therefore, the change in internal energy of the two-vehicle system is:
ΔE = -ΔK = - (1/2)(1300 kg)(2.78 m/s)^2 - (1/2)(1700 kg)(-1.5 m/s)^2 = - 6066.85 J
This negative value indicates that energy was lost during the collision, which is expected in a real-world scenario.
Overall, your approach and calculations were correct. The only error was in the final step of calculating the coefficient of restitution, where you mistakenly added the two final velocities instead of subtracting them. Keep up the good work!
Related to Energy Conservation and Coefficient of Restitution
1. What is energy conservation?
Energy conservation is the practice of reducing the amount of energy used in a system or process. This can be achieved through various methods such as using energy-efficient appliances, optimizing processes, and implementing renewable energy sources.
2. How does energy conservation help the environment?
Energy conservation helps the environment by reducing the amount of greenhouse gas emissions and other pollutants that are released into the atmosphere. It also helps to preserve natural resources and ecosystems.
3. What is the coefficient of restitution?
The coefficient of restitution is a measure of the elasticity of a collision between two objects. It is defined as the ratio of the final velocity to the initial velocity of an object after a collision. A higher coefficient of restitution indicates a more elastic collision.
4. How does the coefficient of restitution affect energy conservation?
The coefficient of restitution plays a role in energy conservation as it determines the amount of kinetic energy that is conserved in a collision. A higher coefficient of restitution means that more kinetic energy is conserved, leading to less energy lost in the collision.
5. What are some real-world applications of energy conservation and coefficient of restitution?
Energy conservation and coefficient of restitution have various real-world applications, such as in sports equipment design, car safety testing, and building design. They are also used in industries such as manufacturing and transportation to optimize processes and reduce energy consumption.
