Energy Considerations When A Satellite Changes Orbit
In summary, the 1 034-kg satellite orbiting the Earth at a constant altitude of 102-km requires 890 MJ of energy to be added in order to move it into a circular orbit with altitude 191 km. The change in the system's kinetic energy can be found using the expression for Total Specific Mechanical Energy, which takes into account both the kinetic and potential energy contributions of the orbit. Objects in higher circular orbits have lower orbital velocities, so the order of specifying the radius reciprocals is important in the kinetic energy formula.
Bashyboy
1,421
A 1 034-kg satellite orbits the Earth at a constant altitude of 102-km.
(a) How much energy must be added to the system to move the satellite into a circular orbit with altitude 191 km?
(b) What is the change in the system's kinetic energy?
(c) What is the change in the system's potential energy?
For (a): [itex]\Delta E = \frac{GM_Em}{2}(\frac{1}{r_i}-\frac{1}{r_f}[/itex]
I have futilely attempted problem many vexing times; I am beginning to regard this as the bane of my existence.
For (a): [itex]r_i = R_E + 102000[/itex] and [itex]r_f = R_E + 191000[/itex], right?
[itex]\Delta E = \frac{GM_E \cdot 1034}{2}(\large \frac{1}{R_E + 102000}-\frac{1}{R_E + 191000}) = 890~MJ[/itex]
For (b) Supposedly there is some relation between gravitational energy and kinetic. I was just going to find the tangential velocity with respect to each orbit, and use those to find the change in kinetic energy. Although, seeing as this direct relationship will provide desired accuracy, what exactly is this relationship?
Your Relevant Equation deals with the kinetic energy of the system. For part (a) you'll need to account for the change in potential energy, too. What's the expression for gravitational potential energy?
You might want to take note that objects in higher circular orbits have lower orbital velocities; So check the order in which you specify the radius reciprocals in your KE formula.
Hint: An expression for the Total Specific Mechanical Energy of an orbit is:
$$\xi = \frac{v^2}{2} - \frac{\mu_E}{r}$$
where ##\mu_E = G M_E##
It combines the Kinetic and Potential energy contributions. The result is in J/kg, the energy per kg for the object in orbit. Multiply by the mass of the object in orbit to obtain the total energy in Joules.
Related to Energy Considerations When A Satellite Changes Orbit
1. How is energy transferred when a satellite changes orbit?
Energy is transferred through the use of thrusters or rockets, which exert a force on the satellite and change its velocity. This change in velocity results in a change in the satellite's kinetic energy, which is the energy associated with its motion.
2. What factors affect the amount of energy needed to change a satellite's orbit?
The amount of energy needed to change a satellite's orbit depends on the satellite's mass, the desired change in velocity, and the altitude of the new orbit. A larger satellite or a larger change in velocity will require more energy, while a lower altitude will require less energy.
3. How does the Earth's gravity affect the energy considerations of a satellite changing orbit?
The Earth's gravity plays a significant role in the energy considerations of a satellite changing orbit. The satellite must overcome the Earth's gravitational pull in order to change its orbit, which requires a significant amount of energy. Additionally, the strength of the Earth's gravity decreases with distance, so a satellite in a higher orbit will require less energy to change its orbit compared to one in a lower orbit.
4. What happens to a satellite's energy when it changes from a higher to a lower orbit?
When a satellite changes from a higher to a lower orbit, it loses potential energy and gains kinetic energy. This is because the satellite is moving closer to the Earth's surface, so it experiences a stronger gravitational pull and gains speed. The overall energy of the satellite remains constant, but it is distributed differently between potential and kinetic energy.
5. How do energy considerations differ for a satellite in a circular orbit compared to an elliptical orbit?
A circular orbit requires a constant amount of energy to maintain, as the satellite is moving at a constant speed. However, an elliptical orbit requires varying amounts of energy as the satellite moves at different speeds at different points in its orbit. This means that a satellite in an elliptical orbit may need to use more energy to maintain its orbit compared to one in a circular orbit.
