Energy consumed by weight of gear on a multiday hike
In summary, the energy consumed during a multiday hike is significantly influenced by the weight of the gear carried. Heavier loads require more energy expenditure, impacting the hiker's stamina and performance. Proper gear selection and weight management are crucial for optimizing energy efficiency and enhancing the overall hiking experience.
freeelectron
TL;DR Summary
Trying to estimate the amount of extra food eaten per unit of gear weight on a long hiking trip
I'm trying to figure out how many extra kcal I would burn on a 600km hike with a 30,000m (30km) positive gain for every additional 100g (or 1kg, whatever) of gear in my backpack.
It would obviously be a quite rough approximation, as there are significant variables such as the efficiency of a human body which must be around 20% and the fact that the weight is not only lifted vertically but also swinging around.
Any idea of a calculation that wouldn't be too wrong?
Thanks
Biology news on Phys.org
Thanks
It looks like every additional kg on a 6h hiking day (3h going up, plus some energy for the flat parts and downhills) with a 10% grade would add ~200 kcal, which doesn't sound totally off, but I expected more.
That's another interesting calculator
https://www.outsideonline.com/outdo...acking/ultimate-backpacking-calorie-estimator
So, if the trip lasts about 24 days, every additional kg of gear would potentially require 4800 additional kcal
It also depends whether you want to lose weight on your hike.
Just for the log: simply by a wrong packaging or an inconvenient shoe you'll be off to the calculation by lot.
Not really an issue for a short hike but you also mentioned 24 days, and that makes safety margins a really tricky problem...
FAQ: Energy consumed by weight of gear on a multiday hike
What is the relationship between the weight of gear and energy expenditure on a multiday hike?
The weight of gear significantly influences energy expenditure during a hike. Heavier loads require more effort to carry, leading to increased calorie burn. Generally, for every additional 10 pounds of gear, a hiker can expend about 10-20% more energy, depending on terrain and individual fitness levels.
How can I estimate the energy consumed based on gear weight?
To estimate energy consumption, you can use the formula: Calories burned = (Weight in pounds x Distance in miles x 0.5) + (Weight of gear in pounds x Distance in miles x 0.1). This gives a rough estimate of calories burned, factoring in both body weight and gear weight over the distance hiked.
Does the type of gear affect energy consumption?
Yes, the type of gear can affect energy consumption. For example, bulky or poorly designed gear may require more energy to maneuver, while lightweight and ergonomic designs can reduce fatigue and energy expenditure. Additionally, the distribution of weight in your pack can also impact your efficiency and energy use.
What strategies can I use to minimize energy consumption related to gear weight?
To minimize energy consumption, consider using lightweight gear, packing only essential items, and distributing weight evenly in your backpack. Additionally, practicing good hiking techniques, such as maintaining a steady pace and taking regular breaks, can help conserve energy during a multiday hike.
How does terrain affect the energy consumed by gear weight?
The terrain significantly impacts energy consumption. Steeper, uneven, or rocky trails require more effort to navigate, amplifying the effects of gear weight on energy expenditure. On flat, even terrain, the impact of gear weight is less pronounced, but it still contributes to overall energy use.
