Energy Density of the gravitational field
In summary, there is no satisfactory way to define the energy density of a gravitational field because it would vary based on coordinates due to the equivalence principle. This is why global energy concepts are necessary. References for the Positive Energy Theorem do not explain this concept, but it is due to the difference between measuring gravitational and electromagnetic fields.
Geometrick
42
Why is there no satisfactory way to define the energy density of a gravitational field? Why must we use global energy concepts? I'm currently reading proofs of the Positive Energy Theorem, but none of the references explains why this is so. Can anyone explain it or point me to a good reference?
Because such an expression would depend on your coordinates due to the equivalence principle. If I measure a graviational field and say it has energy density in point x, then you can Lorentz-transform yourself to an accelerating observer and say that there is no gravitational field, so the energy density is 0.
This is completely different from, let's say, the electromagnetic field.
The energy density of a gravitational field refers to the amount of energy contained within a certain volume of space due to the presence of a gravitational field. However, unlike other types of energy, such as electromagnetic or kinetic energy, there is no satisfactory way to define the energy density of a gravitational field. This is because the concept of energy density is based on the idea of a local energy density, or the amount of energy contained within a small region of space.
In the case of a gravitational field, the energy is not localized to a specific region, but rather is distributed throughout space. This is because gravity is a long-range force, meaning that it can act over large distances. Therefore, it is not possible to assign a specific energy density to a particular point in space.
Instead, in order to understand the energy associated with a gravitational field, we must use global energy concepts. This means looking at the total energy of the system as a whole, rather than trying to define the energy density at a specific point. This is particularly important when considering the Positive Energy Theorem, which states that the total energy of a closed system, including the energy of the gravitational field, must be positive.
There are several reasons why there is no satisfactory way to define the energy density of a gravitational field. One reason is that the concept of energy density assumes a background spacetime, which is not the case in general relativity. In general relativity, the curvature of spacetime is determined by the distribution of matter and energy, including the energy of the gravitational field itself.
Another reason is that the concept of energy density relies on the idea of a local reference frame, which is not well-defined in the presence of a gravitational field. This is due to the fact that gravity affects the motion of objects, making it difficult to define a fixed reference frame.
In summary, the energy density of a gravitational field cannot be defined in a satisfactory way due to the fundamental nature of gravity and the limitations of energy density as a concept. Instead, we must use global energy concepts to understand the energy associated with a gravitational field.
FAQ: Energy Density of the gravitational field
1. What is the concept of Energy Density of the gravitational field?
The Energy Density of the gravitational field is a physical quantity that represents the amount of energy per unit volume of space due to the presence of a gravitational field. It is a measure of how much energy is contained in a given space and is directly related to the strength of the gravitational field.
2. How is Energy Density of the gravitational field calculated?
The Energy Density of the gravitational field is calculated by dividing the total energy of the gravitational field by the volume it occupies. This can be expressed as U/V, where U is the total energy and V is the volume.
3. What are the units of measurement for Energy Density of the gravitational field?
The units of measurement for Energy Density of the gravitational field depend on the system of units being used. In the SI system, it is measured in joules per cubic meter (J/m^3), while in the CGS system it is measured in ergs per cubic centimeter (erg/cm^3).
4. How does the Energy Density of the gravitational field affect the behavior of objects?
The Energy Density of the gravitational field affects the behavior of objects by determining the strength of the gravitational force they experience. Objects with a higher energy density will experience a stronger gravitational force, while objects with a lower energy density will experience a weaker gravitational force.
5. Can the Energy Density of the gravitational field be altered or manipulated?
The Energy Density of the gravitational field is a fundamental property of the universe and cannot be altered or manipulated directly. However, it can be affected by changing the distribution of matter and energy in space, which in turn can alter the strength of the gravitational field.
