Energy dissipated in a resistor
In summary: The 2 should multiply everything inside the cos argument.sin(10t+\frac \pi 4) does equal 1/2(1-cos(2*10t+\frac \pi 4)), but there is a minus sign in front of the cos function.sin(10t+\frac \pi 4)
Bob jefferson
A resistor of resistance 10Kohms has voltage across it described by the function
V(t) = 6sin(10t+pi/4)*exp(-2t) Volts
Calculate the energy dissipated in the resistor between t=0 and t=0.5
I have done the definite integral and have got 0.324 but i am not too sure if i am supposed use this answer in P=V^2/R .
Definite integral sounds good, the question is which integral exactly?
Also, the units of the answer should be supplied.
I integrated this V(t) = 6sin(10t+pi/4)*exp(-2t)
Does the integral ##\int V(t) dt ## have the dimension of an energy?
No
I think the answer should be in joules as its asking for energy dissipated.
That's correct. As DrDu pointed out, the integral you did doesn't have these units. Why did you go away from P = V^2 * R? What are the units of power? How do you go from power to energy?
Hint: Energy is the time integral of power.
so i just multiply 0.5s with the value i obtained from the integration.
No, you need to perform another integration where what you are integrating is the instantaneous power.
Oh so actually putting V^2/r in the integral.
Yes. Try this and tell us what you get.
so would it be some thing like ##\frac 1 R \int_0^{0.5} V^2(t) dt ##
Yes.
phyzguy said:
Yes.
so i need a bit of guidance, would ##sin^2(10t+\frac \pi 4)## equal to ##\frac 1 2(1-cos(2*10t+\frac \pi 4))##
[itex] \sin^2(x) = \frac{1}{2}(1-\cos(2x))[/itex], but that's not exactly what you wrote. The 2 should multiply everything inside the cos argument.
Related to Energy dissipated in a resistor
What is energy dissipation in a resistor?
Energy dissipation in a resistor refers to the process of converting electrical energy into heat energy as current flows through a resistor. This is due to the resistance of the resistor, which causes a voltage drop and results in the production of heat.
How is energy dissipation calculated in a resistor?
Energy dissipation in a resistor can be calculated using the formula E=I^2Rt, where E is energy dissipated, I is the current flowing through the resistor, R is the resistance of the resistor, and t is the time the current flows through the resistor.
What factors affect the amount of energy dissipated in a resistor?
The amount of energy dissipated in a resistor depends on the resistance of the resistor, the current flowing through it, and the duration of the current flow. Additionally, factors such as the temperature and material of the resistor can also affect the amount of energy dissipated.
What happens if too much energy is dissipated in a resistor?
If too much energy is dissipated in a resistor, it can lead to overheating and potentially damage the resistor. This can also cause a decrease in the efficiency of the circuit and may result in the resistor failing to function properly.
How can energy dissipation in a resistor be minimized?
Energy dissipation in a resistor can be minimized by choosing a resistor with a lower resistance value, reducing the current flowing through the resistor, or by using a heat sink to dissipate the excess heat. Additionally, using resistors with higher wattage ratings can also help reduce energy dissipation.
