Energy dissipated in circuit with two capacitors
Then find the total energy. The time taken by the system to reach the equilibrium is determined by the R value.In summary, the total energy dissipated in the resistor as the circuit comes to equilibrium is 21 millijoule. The time taken by the system to reach the equilibrium is determined by the R value. To find the energy dissipated, find the equivalent capacitance when the two capacitors are connected in series, then find the charge drawn from the source, and finally calculate the individual and total energies in the capacitors. The R parameter also plays a role in determining the time taken to reach equilibrium.
Merlione
A 2.0-microfarad capacitor is charged to 250 V. It is then connected to an uncharged 1.0 microfarad capacitor through a 2.2 ohm resistor, by closing switch S in the figure .
Find the total energy dissipated in the resistor as the circuit comes to equilibrium. Hint: Think about charge conservation.
Express your answer using two significant figures.
The answer to the question is 21 millijoule.
C=Q/V
Capacitators in series carry the same charge.
P=I*V
I=V/R
P=I^2*R
U=1/2 * Q * V^2 (energy stored in a capacitor)
I don't really know what to do. I guess charge moves from the charged capacitor to the uncharged one, until the both charges on the capacitors are equal. Moving charge is a current, and this current should give an energy dissipation in the resistor.
I tried some calculations on paper, but there's not much use writing them here, since I seem to need help with the basic approach of this problem.
Thanks in advance,
Merlione.
Hi Merlione, welcome to PF.
After closing the circuit, at equilibrium, what is the common voltage across each capacitor?
Find the initial energy in 2 μF capacitor. Find the final energies in the two capacitors after equilibrium. Find the difference in the energies to find energy dissipated in the resistance.
Thanks for your reply! And for the welcome. :)
I still haven't figured it out.
The initial energy is given by
[tex]
u=\frac{1}{2}*C*V^2
[/tex]
Which gives me 62.5 millijoule.
Then, I thought... Once the circuit has reached equilibrium:
Since capacitors in series carry the same charge, the charge present on the first capacitor will distribute evenly among the two capacitors when the circuit is closed.
[tex]
V1=\frac{Q}{C1}
V2=\frac{Q}{C2}
[/tex]
And this should give me the voltages across each capacitor? Which are 125V and 250V.
However when I calculate the energy stored in the capacitors then, and add them up, I get an energy of 46.8mJ.
The difference is 15.6 mj, and not 21 mj, which is the right answer. So, obviously I'm erring somewhere.
I have to say I do not quite understand this. Shouldn't I include the R parameter somewhere in a formula?
[edit]
Through a sort of backward-calculating-with-the-answer, using the energy formula
[tex]
u=\frac{1}{2}*C*V^2
[/tex]
Filled in the ' replacement' capacitance of the the capicitances, added reciprocally, and U of 21 millijoule, I derive a voltage of 250 volts.
Which is the voltage across the capacitor in the stage before eq. What I wonder is, would it be correct to say that, once this switch is closed, the voltage across the total circuit is 250 volts? And you can simply use this along with the replacement capacitance to find a new stored energy...?
A bit confused and in doubt, waiting for the helper who'll make it a little more clear...
~Merlione.
The R parameter decides the time taken by the system to reach the equilibrium.
Find the equivalent capacity when the two capacitors are connected in series.
Then find the charge Q drawn from the source. This charge is common for both the capacitors. Then find the individual energies in the capacitor.
FAQ: Energy dissipated in circuit with two capacitors
What is energy dissipation in a circuit with two capacitors?
Energy dissipation in a circuit with two capacitors refers to the process of converting electrical energy into heat energy due to the presence of resistance in the circuit. This occurs when the capacitors are being charged or discharged.
How is energy dissipated calculated in a circuit with two capacitors?
The energy dissipated in a circuit with two capacitors can be calculated using the formula E = 1/2 CV2, where C is the capacitance of the capacitors and V is the voltage across them.
What factors affect the amount of energy dissipated in a circuit with two capacitors?
The amount of energy dissipated in a circuit with two capacitors is affected by the capacitance of the capacitors, the voltage across them, and the resistance in the circuit. Higher capacitance and voltage, as well as lower resistance, will result in a greater amount of energy dissipated.
How does energy dissipation impact the performance of a circuit with two capacitors?
If a significant amount of energy is being dissipated in a circuit with two capacitors, it can lead to a decrease in the overall efficiency and performance of the circuit. This is because the energy that is dissipated is not being used for its intended purpose and is instead being lost as heat.
Can energy dissipation be reduced in a circuit with two capacitors?
Yes, energy dissipation can be reduced in a circuit with two capacitors by using capacitors with lower resistance, increasing the capacitance, or reducing the voltage across the capacitors. Additionally, using materials with higher conductivity for the circuit can also help reduce energy dissipation.
