Energy, force, acceleration, and work with time dependent position
In summary, the conversation discusses a 4.00-kg particle moving along the x axis with its position varying over time according to x = t + 2.0t^3. The homework equations K.E. = 1/2 m v^2, acceleration = 12t, and force = 48t are used to find the kinetic energy, acceleration and force of the particle at any given time. The individual also discusses their attempt to find the work done on the particle in the interval t = 0 to t = 2.00 s, and raises a question about the discrepancy between using the force formula and the kinetic energy formula to find the work.
bdh2991
103
A 4.00-kg particle moves along the x axis. Its position
varies with time according to x = t + 2.0t^3, where x is in
meters and t is in seconds. Find (a) the kinetic energy of
the particle at any time t, (b) the acceleration of the particle
and the force acting on it at time t, and (c) the work done
on the particle in the interval t = 0 to t = 2.00 s.
K.E. = 1/2 m v^2 = 2 + 24t^2 + 72t^4
acceleration = 12t
force = 48t
I got the answers as you can see for part a and b, and i actually got the right answer eventually for part c as well using W = ΔK.E...however, the first time i tried getting the work i used the formula W = ∫F dot dx, evaluated from 0 to 2. which lead me to:
48t (t + 2t^3) from 0 to 2
which gave me the answer W = 1728 J, but that is not the same answer i got for W = ΔK.E. and i can't figure out why using the force to find work did not yield the right answer...any idea?
OK, this is just a thought, I also don't know for sure, but to calculate the work which is done, the force has to be applied along the path? If we multiply 48t (t + 2t^3), I'm not sure we achieve this.
how? if F = 48t and x = (t+3t^3)
While force is a straight line and x is a polynomial of third order?
I hope someone comes with better answer.
The equation is W=∫Fdx
That requires F as a function of x, and to integrate over x. To get it as a function of x requires solving a cubic polynomial equation. Converting that to time is a less difficult.
The first step would be to calculate dx=f(t)dt (hint, what is dx/dt?). Now you have W=∫F(t)f(t)dt. Now you can integrate over time.
FAQ: Energy, force, acceleration, and work with time dependent position
What is the relationship between energy and force?
The relationship between energy and force can be described by Newton's second law of motion, which states that the force applied to an object is equal to its mass multiplied by its acceleration. This means that the greater the force applied, the more energy is transferred to the object.
How does acceleration affect an object's energy?
The acceleration of an object affects its energy by changing its speed and/or direction. When an object accelerates, its kinetic energy increases or decreases depending on the direction of the acceleration. Additionally, the potential energy of an object may also change if its position changes due to acceleration.
What is the role of work in energy and force?
Work is the process of transferring energy from one object to another by applying a force over a certain distance. It is an essential aspect of understanding energy and force because it allows us to quantify the amount of energy being transferred and determine the resulting acceleration of an object.
How does time affect position in relation to energy, force, and acceleration?
Time plays a crucial role in the relationship between energy, force, and acceleration. When an object's position changes over time, its energy and/or force will also change accordingly. This is because the longer a force is applied, the more energy is transferred and the greater the change in acceleration.
Can energy, force, and acceleration be dependent on position?
Yes, energy, force, and acceleration can all be dependent on an object's position. For example, an object's potential energy depends on its position relative to other objects, while its kinetic energy depends on its velocity and direction of motion at a given point in time. The force applied to an object is also affected by its position, as the direction and magnitude of the force can change depending on the object's location.
