Energy from the sun that reaches the earth
The discussion focuses on calculating the energy emitted by the sun and how much of that energy reaches the Earth's surface. It highlights that the sun emits approximately 600 million tons of matter per second, and the energy can be calculated using E=mc^2. The concept of the inverse square law is introduced, explaining that energy decreases with distance due to the spreading of power over larger surface areas. Participants discuss the importance of knowing the distance from the sun to the Earth and the Earth's diameter for accurate calculations. The conversation emphasizes understanding how energy diminishes as it travels through space.
Backup
The sun consumes about 600 million tons of matter per second, How much energy is that? Of this energy how much reaches the surface of the earth
E=mc^2
I solved the first part, but how do I start the second?
Have you been given a value of the distance from the Sun to the Earth, and the diameter of the Earth? They are useful things to know in this context.
Yeah I have the distance of and the radius. I know the speed of light. Problem I have is how does energy decrease over a distance with a speed
It's an inverse square law because, assuming the sun radiates equally in all directions, then the same amount of power is being spread out over a sphere of successively larger and larger surface area as the distance from the sun increases. This means that the power received (per unit area) at any location decreases with distance in inverse proportion to the area of that sphere.
http://en.wikipedia.org/wiki/Inverse-square_law
What fraction of the solid angle surrounding the sun is subtended by the earth?
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
